Hmmmm... no car insurance on the racetrack for the cars... no problem though with private health insurance?
I'm with Medibank Private, I don't need to let them know I'm taking part in high risk activities do I?
Yeah I think I need to get some private health insurance.. which mobs are good?
edit: which one you got birds?
http://www.nib.com.au/health-insurance/choose-cover/hospital?hospital=MID&extras=Wellbeing
Dunno which one I'll have to look at my last mail out, but what they take out of my bank every fortnight didn't add to to any of those options so I might make sure I'm not getting ripped off lol
They jack it up a few dollars a fortnight every few months or so, pretty shit but that's inflation and business I guess.
I don't claim that much so I've spent thousands on premiums over the years with little return, save for some cheap prescription glasses and wisdom tooth removal and physio, but I see that as a good thing. Older you get the more you break.
Unsure of this one to be honest
Might have to ask them
Just crawl away and say you fell in a gutter / got bashed near a race track by some unsavory lads
I have the absolute top cover... I can tell you it's worth it.
I nearly died in the public system... and my medical bills were HUUUUUGE after a few weeks in private.
Yeah i have zero faith in public im not anti private health cover im anti the forced down my throat nature of it lol
I get my monies worth back on private health insurance through dental + optical every year.
but i also understand that even on private cover, if there are no available beds in a hospital or a queue for the emergency room, you will have to wait like the rest of the plebs.
Much shorter line though, especially for elective
sauvicwl.
one of my workers lent a guy he knows 20k... he also has a written contract from him stating that it will be paid back,
the flamin mongrel isnt paying.
what can he do? hes pretty distressed about it. trusted the guy, enough to loan him 20gs.
sauvicwl.
Idiot.
Only lend money you can afford not to get back.
Trust no one.
  • Like 2
Just do it.
My step brother is a conspiracy theory nut and it cost 12k for each baby. 24k later and he still refuses lol.
sauvicwl.
All seriousness 20k is a huge amount to lend man he really should have got some collateral or realized it was a horrible idea
Idiot.
Trust no one.
This times a thousand
Unless you've lent them small quantities before and they've gradually built up a large equity of trust from you through increased amounts, in which case you should prolly get rid of your deadshit mate who clearly can't budget
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
