http://www.australianunions.org.au/national_day_of_action
unions are just a bunch of Nazi douchbags with small gentialia...
(yes I am sitting behind bullet proof glass currently)
(and hoping sarcasm comes across fine on the Internets)
  • Like 1
Don't be ridiculous I told you I'll happily take a labor government but given that they haven't delivered a surplus in longer than your existence on this planet it's clear to blind Freddy they have no idea how to run the country and the budget so that single damning fact alone says they are incompetent without getting started on the other glaring flaws.
Actually, the last Labor surplus was delivered by Paul Keating when I was well and truly ailve.
It came a few budgets after a recession (which I also remember as being quite scary,) and it was ended by another recession from which it took howard a few budgets to recover.
After that were a few good years, fiscally speaking, followed by the GFC which crushed the budget and would have doe so whether ALP or LNP were running the show.
This idea that Laabor can't handle budgets is absolutely retarded, do you think they get their treasurers from the footy club? They are just as capable as LNP. Fact is external factors play a bigger role in countries returning a surplus than any other single factor.
Considering australia has never lost it's AAA credit rating, I don't see that we are in the imminent danger that the LNP have used as an electiob scare tactic.
I'm not a Labor supporter by any means. I just hate this current government and people assume that for some reason means i must be "a lefty".
Turns out the desalination plant has been sitting idle for 3 years, government still has to pay yearly fee as part of contract.
Forgot all about that white elephant. haha
Well, that is not really anything to do with the federal budget lol
But yes, it was an epic clusterf**k
Labor are hopeless and debt has always increased under labor leadership as shown here - so while external factors certainly play a role, so does poor management. $900 handouts, insulation debacle, school building joke? need i go on.. all under just ONE labor gov mind you.. if you dont think that going the same way we are now is going to lead to huge problems you got your head firmly in greens propaganda. AO-Chart1-160514.png
  • Like 1
I never said we should go and spend all the money on shit because budget's don't matter, what I said was it isn't as bad as LNP propaganda would lead you to believe.
Of course we need to work towards a surplus eventually but it doesn't need to be via extreme harsh measures and done by the next budget.
As I said a few pages back we need to look at it as a longer term proposition, not just an election tactic.
Now lets overlay that with a graph of the economy acceleration / deceleration and it won't be so much of a Liberal Skewed Infographic
good luck finding a graph regarding the federal budget that doesn't have an agenda
The proposed measures labelled extreme are about $15 billion worth which is nowhere near enough to get back to surplus so if people think these measure are bad wait and see what will come in the future when it's well past the current deficit
  • Like 1
>After posts like these you can't see why people say you are a lefty? Farkin lol
>Let's just blindly spend more cos it's exclusively external factors that influence our budget position hey? Hey guys at least we aren't Greece
>Budget concerns are no worse a 'scare tactic' than dezz's mates' union bullshit
>Are you still taking the piss or nah?
All I'm seeing that graphic show is that even when we're in deficit, the world doesn't end, because it happens over and over again.
So why now are the LNP jumping up and down that Labor are destroying the country? When it's a recurring cycle which hasn't killed us at all, we still continue to prosper and haven't financially imploded.
Economic Stimulus means projects, projects cost money, projects mean jobs, jobs mean economic rotation...
The circle jerk continues for another term in office.
what that graph also shows is for every major Labor deficit in recent times (that were caused by external precipitants) said deficit was shrinking every year and was on it's way to an eventual surplus.
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
