Still worth it if you only drive on weekends and car is 25 years old
Which was the point of the scheme before every moron with a car 5cm off the ground and a straight out exhaust made their own car club
  • Like 1
I did this, it really doesn't stay shiny as long as you think it would (try 1 month...)
Yeah I don't think their products are that fantastic
Got 86 detailed there and the wax didn't last long at all
Definitely detailers doing the same thing for half the money
I take my car to Dave
+1 to Dave.
Got detailer coming over over on sat, charging heaps more than Dave and promoting unrequired products.
On topic, speaking to Mick from micolour and he doesn't endorse the use of protective coatings etc
Oh, I didn't mean final inspection (is that who you thought I meant?)
I meant the key doesn't stay so biuriful..
fyi for those that care,
club permit scheme is now officially f**ked.
RWC and VASS cert for modifications only way to get one now
Was only a matter of time, the amount of complete shit boxes I see driving around with club rego is a joke. Then there's the ridiculously modified unroadworthy ones as well
Soooooo I bumped into an Andrew Bolt "article"
It was just a massive sook about the ABC trying to destroy Abbott and the LNP. He went on to cry incessantly about ABC shows putting on more left wing guests than right and also speaking over conservatives... and that would be fine, as there is definitely a left wing agenda with the ABC at times...
BUT
I also watched an episode of "the Bolt Report" and lets just say he's not exactly in a position to complain about bench stacking or talking over people with opposing political views lol.
It's "womans day" quality journalism thinly disguised as political commentary.
By that token I also read a Waleed Aly "article" that was just as whingy, and equally devoid of merit...
The abc is completely left wing - q&a is stacked massively
It's as left as bolt is right. Makes sense though because greenie hipsters watch abc so it's of little surprise
BUT
Bolt can be as biased as he wants on his private-funded tv show.
However abc has an obligation to be unbiased due to government funded tv station.
As explained here, abc caught breaching guidelines.
http://m.smh.com.au/federal-politics/political-news/sarah-ferguson-interview-with-joe-hockey-breached-abc-bias-guidelines-review-20150217-13gbmj.html
& another
http://m.heraldsun.com.au/news/opinion/bias-against-tony-abbott-is-truly-sickening/story-fni0ffxg-1227224642841
"It is about an ABC that last week beat up Abbott for days for referring to a “holocaust of jobs” — he insulted Jews!, was the deceitful claim — yet didn’t complain when Labor’s Paul Keating referred to an “economic holocaust” and Greens senator Scott Ludlam to an “environmental holocaust”."
  • Like 1
Oh I see
Yes I expect it will turn MATT soon...
But it's a hell of a lot shinier than the existing key and I only have one key lol
I also bought a cheap Nissan key to use on the daily grind
Shiny key can be for security guard meets
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
