apologies to traction tyres... rear suspension just hasnt got that much rear camber to give. plus needs a roll.
will hunt down some Z33 camber kits and fingers crossed they'll fit :unsure: thats what the 'muricans say they use
The statistics aren't accurate for reasons I raised in my post
It's not foreign ownership when the purchaser is a resident
You'd need statistics on ethnicity of home buyers and multiple home buyers, but can't do that for obvious reasons
How many people do you think are trusting friends or family with hundreds of thousands possibly millions of dollars to get a house to get around laws? Not many Id imagine especially since they can apply to the foreign investment review board for permission
well the whole point for the $5000 fee for international investors is to fund investigations into purchases which were cutting corners/illegal.
"The higher application fees and penalties are expected to fund an improved enforcement of the current foreign investment rules.
"We need to make sure that all foreign investors are following the rules, and that those foreign investors who break the rules are not able to profit from breaking the law," the Prime Minister, Tony Abbott, said in launching the paper."
http://news.domain.com.au/domain/real-estate-news/foreign-buyers-set-to-be-hit-with-steep-fees-to-buy-australian-property-20150225-13ob2a.html
I hear Ya man but being in the industry and having contacts all over im gonna go with the info im getting from people on the front line it's a non issue - just a popular policy for the 'battlers' / art students who took gap years and fkd around through their 20s and wanna blame someone for the fact they can't afford a house.
Heaps. That's like saying why are there boat people when they can just wait in line for immigration. The figures don't add up when I hear of so many auctions being dominated by the Chinese - and I'm expected to believe that only a billion or so dollars traded hands from foreign investors = only ~2000 or so homes Australia wide?
They don't trust their own government or banks / local investments so send over here instead. Australian property market is the new Swiss bank account.
Just cos they look chinese doesn't make them a foreigner man, plenty of 2nd, 3rd, 4th generation permanent residents just as entitled to buy as you are.
Well if im having difficulty on a FIFO professional income, I'd hate to imagine how art students would have any chance...
  • Like 1
    • Dear folks My family members have 4 different cars : Triton 2015 and Corolla 2011 and Mazda3 2012 and Hyundai Elantra 2014 Looking to buy engine oil funnel spill free What I found are are below  https://www.amazon.com/gp/aw/d/B0BBTTJNKX?ref=ppx_pt2_mob_b_prod_image&th=1 https://www.ebay.com.au/itm/145553221359?srsltid=AfmBOoqYBU6Ptw0LU_bAp_k67U3qkF97HHvePkA7iHZw8vUmiwoIRaRr https://www.amazon.com/gp/product/B09X23TCS5?th=1 Is there a funnel with attachment that fits most cars ? Don't mind to spend for a decent quality  Thx
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
