Bank valuations should never be made privvy to the client although some banks allow it.
It's for litigious reasons.
I wpuld never let a client know... you think it's bad for a house try explaining to someone you aren't telling them what the commercial val is when you just charged 10k for it :P
capped repayments?
So why don't NAB just offer it themselves...
How low you rekin I could get CBA to drop it (without capping repayments), and what's the best way to get em to do it?
CBA, just speak to them. They are some of the best with rate matching. Their bankers have more pricing discretion than most.
Yeah but do I need a rate from someone else for them to match? Or just call up and say I want it lowered or I'll go somewhere else
You've confused me with the LVR shit now too, I'd imagine it's better to have a lower ratio, ie you owe f**k all but your house is worth heaps...
Pretty sure I'm well under 80% even without knowing the value of this place
Even if it hasn't gone up a cent since I built it, I'm well below 80%.
They're selling blocks of land across the road for a new estate, might go sus out what they're worth to give me an idea of what my block is worth now
Just go in with U bank's offer and tell them you will jump ship but would like to see if they can match it or at least come close as you really like the CBA service.
They wont beat it, but they might drop your rate
Banks value at contract price - for purchase anyway never more and almost never less unless you over pay big time
Capped is shit I went variable cos same problem could only pay max 5% over per annum how spose to pay off fast with that shite I'm with Macquarie think the variable is down around 4.5 now they sent me a letter the other day but eh just keep payin same as original
They sent the valuer out to inspect so I don't think they're going off what I paid... If they take into account shit I've done like landscaping, concrete, air con etc it'd have to be worth a bit more than it cost to build, and I'd say the land has gone up even if only a little. Will have to sus out the blocks across the road to get an idea...
She said she's pre approved me for around $400k to buy a rental so I can't be doing too badly in their eyes.
Have since changed plans since meeting with her though.. Instead of buying a place solely to rent out, I figure I'll buy a block in an area I wanna live, build a new place there then rent this one out... Just need to find a wide block in the area I want, need the width to fit a triple garage..
Banks usually hand out pre approval at 80% LVR.
Talk to a mortgage broker, they'll push it to 95% LVR; meaning greater loan for smaller equity/deposit.
Yeahhh m8888 V8's!
Fark the JDM's
Saw this on friends facebook post. Apparently the admins drive ADM Jap cars
*Note not a member of the club, there seems to be a billion different facebook groups
11050234_1053838521299984_76916896089164
My cars so ADM it's even on my numberplates
YbIba9J.jpg?1
But I bet being turbro would still be allowed in their 'fancy' JDM tyte yo club.
With higher risk and likely worse rates.
No one (virtually) is going to lend at 95% without LMI which at $400k will slug you an extra $8-10k
As an investment property that you may want to sell at any time depending on the market it is unwise to gear it so highly. For an owner/occupier it's more logical as you intend to live there for a while.
Also Simon fast n loud is a sick show!
I recommend getting on it peeps.
Farken Optus, find out 2 weeks after signing up for another 2 years of fetch tv that discovery turbo has been dropped from their line up...Not happy
Has anybody tried this new Maxthon browser...seems pretty good so far..
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
