I think not paying out is more commercial. The type of people who buy scratchies are probably unlikely to boycott the company
Say $100k, its a pittance to tattersals.... I dont think they'd choose the negative press over it.
Especially if it was a legit purchased ticket and a kid had done it or something.
Yeah I was just being difficult lol
who would like to open a restaurant?
pretty awesome location on the hume hwy is up for lease, tennant did a runner, land L0rd is despo for $$
also
VQ coil packs
R34 dashboards
22s on r33s
rogercordia
also
VQ coil packs
R34 dashboards
22s on r33s
rogercordia
Holy jesus no
Organised to get the surfaces decked this morning, then last night spotted the crack that I missed when it was dirty/lower light... so I hit up drift sales and going to go grab a std one from Jack Phillips tonight...
Will last through the weekend... Might look at a different one if I go a larger turbo in the future, however I'm pretty sure this one only overheated and cracked due to my decision to keep going hard even with the intake leak...
When you're getting detonation on E85 because it's running too RICH, its probably time to back off a bit ;)
No doubt the tenant did a runner because they couldn't handle the pressure of such a prosperous business
Beat me to it
Heard a good one the other day; guy selling one of those self wash car washes...said it would turnover 3k a week and only selling cause he had a bad back
Beat me to it
The old "turnover" myth .. Has zero to do with profits but don't let making money get in the way of a good oppertunity !
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
