I hope they don't catch them
And this is why
Translation:
We're very confident that with the help of the enthusiast communities whom we regularly and unfairly target and tax for revenue on a daily basis, we can oust a couple of people from within it.
Really? Can not think of a better analogy than than the Sheriff of Nottingham asking people to kindly rat out the whereabouts of Robin Hood
Aca detectives did a follow up segment today identifying the possible drivers. Saw the recording on fb. Someone link a youtube recording.
Al, thought about the new Hyundai Genesis?
A shit tonne of car for the money... Top spec possible is like $87k. Things are baller and dudes in the US are aparently pulling 500hp from them
A shit tonne of car for the money... top spec possible is like 87k. Things are baller and dudes in the US are pulling 500hp from them now
Actually don't mind it similar to the kia k900 that thing is baller as but not sold here yet.
Id just worry about resale due to brand stigma. Guy I worked with had a kia sorrento I think they're called for the money was a damn good car great warranty never had any headaches with it either
I'd take the punt on resale TBH...
I don't think it will be that bad. looking at how they have surged in the SUV market people are starting to change minds already.
If I was in that market it would probably be my choice
Mohsen Younes UAKfXU8yqXv.pngfeeling broken
8 mins ·
Knock knock?
Whos there?
Bottom end.
My engine is working, thus according to the laws of relativity, luck can never be gained or lost, only redistributed.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
