AV kunce... bought new 5.1 speaker setup.. thinking it would be a direct swap for my existing yamaha speakers... the new ones being a better model have 'bi connection' available as opposed to the old set with just the standard one pair of terminals per front speaker...
apparenty 'bi connection 'decreases modulation distortion caused by electric resistance of the cables and driving current of the speakers. Consequently, purer sound quality can be achieved'
That'll get done on my holidays...
Now the new sub...the old sub was just a direct plug in to both the sub and the amp... new sub has terminals for speaker wire connection or plug in inputs... 1 using a mono pin cable, not included of course, which connects to the 'subwoofer low pass' terminal on the amp... or using an 'audio pin cable', also not supplied, which is a 2 plug setup which goes to the 'split subwoofer' inputs on the amp....
Which of these options would give the best results?
I'm looking at you Odium.
  • Like 1
bi-amped means to split the signal and run two seperate outputs to the speakers
you need an amp that supports channel a and channel b - or dual amp
my setup is like
you basically run two pairs of speaker wires to each speaker
does the amp have speaker A and Speaker B ?
given that it's a 5.1 its unlikey
does the amp have subout ?
bi-amp is better but if your amp doesnt support it, life goes on. just bridge the terminals so that the single speaker wire goes to both terminals if that makes sense
ie dont cross the wires, but merge them
my setup is like
The instructions that came with the speakers actually say you can put the 2 pairs of cables into the same terminals on the amp if only one pair of front speaker terminals is available..
yeah you can split the wires, use a bridge tool and run completely seperate - from two seperate outputs
so on my stereo amp
i have channel A and channel B on the amp
Channel A goes to speakers on input #1 on the speakers
channel b goes to speakers on input #2 on the speakers
then on the amp when Channel A and B are turned on you hear normal music
if you only turn on channel a - you only hear trebble, if you only turn on B you only hear bass
Why would you ever want only treble or bass?
From what these instructions say, its not about doing that at all, just about increasing the sound quality... They're connected as normal for now, if I cbf I'll do the bi connection using the single front speaker terminal pairs, but I doubt I'll be able to hear any difference anyway.
As for the sub, the speaker wire option with my amp only having the 1 set of front speaker terminals, I'll go with the AV cable connection instead.
What you're referring to is Bi-Wiring, not Bi-Amping... very different concepts... and neither will increase your chances of a threesome with two bi girls, trust me, I know... The Onkyo Sales Rep lied to me.
http://en.wikipedia.org/wiki/Bi-wiring .... "Buy-Wiring", ha.
Your success will only determine the type of car that I buy you, not whether I buy you a car or not...I trust you'll look after it as if you had saved for it yourself
/genyparent
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
