Shit you really blew it apart!
How else you expect to replace the piston rings he fried?
Farken spent all afternoon getting my gearbox back in cus I was being a stubborn flamin mongrel and didn't wanna take the dump pipe off. Then had to take off my new HEL braided clutch line cus they hadn't put the threads down far enough on the hard line fitting so it was leaking :/. New clutch feels great though.
What is wrong with people?
1) coppers setup a breatho in dandenong today next to the dandy law courts. Block off 1 lane from either side, bottlenecking traffic on both sides and breath-testing every single car. Congestion backed up 3 intersections either side of it.
2) about 5 cars from the setup the queue hadn't moved in almost 5mins and I can see a copper getting very animated and frustrated trying to explain to someone how to perform a breath test. Because clearly they didn't understand. Luckily no one can move around so we all have to sit there and wait whilst someone who knew interpretive dance could assist.
3) rowville shops car park, I watched a man in his 50-60's walk around a car park looking for his car. Came across a BMW X5, looked through the windows, tried the door handle, looked through another window and then walk off looking very confused. He then saw a woman he knew standing next to a black Toyota prado, he wasn't even the one with the f**king keys. (He didn't come across as being "special")
The people of melbourne
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
