There's also an option to "automatically remove once downloaded" but yes, for a millisecond of time, you'd have the file.
However, there's definitely a global trend about people chased for this kind of thing being seeders, long time, multiple files, essentially acting as distributors for others to obtain files.
Maybe it's the most low hanging fruit for legislators to go after, though.
Then again it gets mired down. What if you just share out the DVD that's sitting in your DVD player that you legally purchased?
"oops it was taken without my knowledge, those tricky pirates!111"
So can someone explain VPN and what you need to do to avoid being caught?
in short what it does is create a tunnel from your system to the VPN server then the VPN server connects to the internet.
so all the traffic from your system outbound is encrypted and has no identifying details.
and as there would be hundreds of users on the VPN server no-one knows who's traffic is whos.
great for secruity for public networks.
Some also have servers in multiple countries you can connect to so lets say you ahve a foxtel Go account but are in Germany, Foxtel block the traffic. but you can select a AU server and stream your V8Supercars. (this is a completely random scenario as I'm sure you can imagine)
but lets say you are being a little dodgy and want to download a tv show or a movie, (not that any-one here would)
so long as you pick a VPN provider that does not keep logs of traffic there is no-way to track who is downloading what data, even better select one of those end points i a foringe country that has no data laws.
there are a bunch of servers that do this for a nominal fee. Below is the one I use
https://www.ipvanish.com/why-vpn.php
https://www.ipvanish.com/privacy-policy.php#1
  • Like 2
It's still illegal. you cannot make a backup copy for personal use.
this was covered off during some PS2 lawsuits years ago.
Edit it was something about circumventing security in place by the movie studios.
Double Edit: they are not going after you for downloading..and they cannot at this point, it is the seeding/sharing that is illegal, same as selling a pirate DVD is illegal.
I wouldn't buy one that didn't already have the 6 speed box.
they are cheeeeeap and I need a train station car that is still kinda enjoyable
Inark bought one a while ago, not sure if he still has it
Got it cheap and had quite a bit done to it
Want one but with an off tap l28 in it
would be fun to go to:
https://www.facebook.com/events/754949701270445
just hope those who had top gear tickets got refunds...
still happening, its just called the james , jeremy and richard show.
all top gear branding dropped from the tours.
refund if you don;t want to go to the new version, or a ticket to the new one.
so yeah no-one screwed over. well unless you bought accom, flights etc
Just bought these for the skyline... $30 (new is $360 from Nengun)... in Typical Drift Sales fashion, no mention of the fact that they're missing the rod end spacers until I'm organising a time and location for pickup.
Ah well, should be able to source some that are suitable from Fulcrum or Hardrace etc.
Why is every fgt including a pic of their car in their wall post saying they might go? Who gives a shit if your evo 7 or Hyundai is there, what a fkin draw card
we do this on SAU events as well, once a few post it up shows others that no you don;t need a out and out race car or 100% perfect show car, any-one can attend.
bumps up interest as well.
think of it as a marketing thing.
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
