I just got a cheap second-hand Logitech GT. Not as nice as a G27 but can't complain for $60.
If you and Michael compete next week, should be a pretty full grid. Can keep me company at the back of the pack :P
Best thing I did was focus on setup and tweaking FOV to suit my sitting distance from the screen. Really helped me judge braking distances
Leroy is right about setup. Brake setup is uber important when its a fixed setup race too ;)
Playing a little bit with FOV am i right in assuming for a single 70" about 1.5meters away i should basically be using low as fark 45FOV? I think i need to sit closer lol.
From my brief research looks like single monitor = 45-60ish and triple much higher correct?
Edited by UNR33L
Edge motorworks sounds promising
Call and Barry answers
Him: You vont stroker?
Me: Yeah that or an RB30 bottom end
Him: Yah 30 torque monsta...lots of power...do that
I like where this is going
  • Like 5
lol.
I actually heard that in his accent too.
Thought you were going racepace rebuild?
That was the preference but
Last communication to RP was to keep me regularly updated on free spaces in the workshop
2 months later still nothing
I'll pass
No hard feelings from me, but it ain't hard to send a weekly email or knock back the work and say try again in 3 months or something...stringing along is wasting everyone's time when my engine could be getting built right now
They obviously get enough work from their loyal motorsport customers and need to service them as a priority which is fine, but I need to get this thing on the road
Hatish you tried Easey’s burgers yet?
do you rate?
tried Laurie Dee's the Burger adventure winner from last year this week, was very unimpressed.
looking for a new one.
I went to bad boys Melbourne. $15 meal was pretty good value. Tasted great
Took 2.5 hours to drive from sunbury to rowville this arvo.
Mostly due to the Burnley tunnel having a lane closed to half of it for no reason at all.
And then this weekend is going to be spent cursing at the astra.
do you rate?
Yeah, the owner and chef are mates of mine.
I went when it was a popup for a week on the rooftop of an apartment building on bourke st and it was amazing.
If jimmy & josh can keep up that quality then it will be number 1 without fail
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
