leeroy played some official race on iracing.. fark me annoying I just kept getting taken out then finished like 11th, nek minit my license goes down a few points because of all the incidents
then I race a 'popular race' not official, come 2nd and it doesn't count toward anything! raging
gee you're doing better than I am. did a time trail event thing once and that was the only non SAU race for me.
Shift kit installed in the gloria, cut part of the exhaust off and got a second hand diff to put it in it soon.
This thing is turning more and more commo-spec by the month.
This was oval track.. wasnt that hard just full throttle and turn hope not to get taken out lol
I better practice those SAU race cars for Wednesday they seem pretty slow tho
Who's going to sandown this saturday? need to kick it with some wastelanders if I go down for a watch
Edited by UNR33L
