Fair call
In which case I think you should take a look at it
These cars will be worth their money one day, mark my words. The most popular model of Skyline and all of them thrashed out / parted out or written off one day. Will be the new VL turbo but not a piece of shit.
  • Like 1
Decent respray is a 4k+ affair, I reckon that's a worthwhile addition for a near 20 year old car if it's a good colour/job
But hardly any mods is why I don't think it's worth anywhere near 12k - would expect at least ecu / injectors / turbo for anywhere close to that
But that's why I don't think it's worth anywhere near 12k - would expect at least ecu / injectors / turbo for anywhere close to that
I'm not saying it's not a nice looking car, just that there's nothing really done to it that make it look any different from the other 3 million S2 R33's around, apart from the wheels, which aren't included.
The thought of buying a skyline sometimes crosses my mind... If I was to go down that path instead of something much pricier like M3/AMG/35 GTR etc, it would more than likely turn out to be quite an animal..
But alas, I think those days are behind me
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
