My car is alright, ran out of tyre grip approaching turn 1, locked up, released, locked up again, released, locked up again... just went straight off the track into the kitty litter at about 120.
Tell you what, that wall comes at you mighty quickly... Ripped off the bottom of the front bar, cooler piping, bent the body metal where the cooler piping hole is, ripped a rubber joiner in half. Don't want to start the car since there's like a kg of sand and gravel in the piping... trailered it home and its now sitting on the street out the front of my house, now I need to work how how to get it 20m up my driveway into the garage. I'm thinking just AFM directly onto the crossover pipe so it'll run.
Went out with some of the guys tonight for dinner and drinks, 54 Jack and Cokes later I'm home.
bahahaha, probably went a little over zealous thinking it was only one parade lap - got a bit out of shape into 3rd gear wheel speed must of shot up to 150km/h + easy and touched the grass nek minit in a spin, too much iracing not enough real racing
serves me right for f**king around a bit - got some stern looks from the officials down pitt straight
Edited by UNR33L
undo all pipes, unplug afm, drive it up on limp mode. done.
good lines till then.
did the exact same thing on my first ever track day.
actually on my first lap of my first ever track day!
hit gravel trap, realized I was going to stop...looking in mirror saw a MX5 coming at me backwards....powered the FK out of that sand trap!!!!!
changed underwear...went back out.
    • Thank you, 100% the intent. New coils were due and the 17" sixers look/feel loads better than the stock wheels. The aero options are so spot on.   Thanks for the warm welcome, all!
    • 98 r34 gtt Been rocking my latest setup and car running like never before. Have put a good 200 miles on it since all the latest changes and additions. everything is dialed in and have been driving it a bunch.   However, all a sudden last weekend as soon as I pushed throttle passed 4k and the engine stumbles, (slow or fast acceleration) hesitates and doesn’t go above 4100 or so, like a misfire. Everything else seems fine. I had a “good” set of coil packs that I removed from car when I first got it when I changed them over to new coils. I swapped out current ones for those, but no change. I also changed the plugs, no change. Seems to rev over 4 when out of gear with no load just fine no “misfire”, but as soon as its in gear with a load of any kind, it “misfires” as soon as rpm drop back below 4 k it runs perfectly, smooth, starts, restarts and drives fine as long as I keep it below 4 k while in gear. All readings look fine, no CEL   Any idea as to what could all a sudden cause an issue when pushing rpms passed 4 k?
    • When you say your cams are 272/262 is that 272in and 262ex?
    • We're arguing semantics. I am saying 45 accel and a 55 deccel ramp are "2 ways". Even a 45 degree ramp and an 89 degree ramp is "2 ways", because it is literally... two ways. The cusco 55/30 ramp is a 2 way. It's two ways. I get it though - in normal nomenclature a "2 way" would be 45/45 or 55/55 or 60/60 i.e the same locking in both directions. And something like 45/65 would be considered "1.5 way". I would then say if we're getting into the nitty gritty then every locking diff is a "2 way" diff and we should not speak in 1.5, or 2 ways but ramp angles instead. Which ofc if one of those ramp angles is 90deg, that side is not doing any locking. :p So Nismo don't obviously sell 3 things. The fact of the matter that they only sell two items really goes to show that there's a 2 way and a "1,5 way" which is really a 1 way. I believe the actual lockup for the 'adjustability' of the GT pro is really just setting preload for when the ramps actually start locking up. It's not changing how much 'wayness' there is. It is (somehow) horribly explained. People just buy whatever diff and go "locks up good bruh" and that's what ends up on socials forever.
