i love the people that go on about Reps being deadly...
If half the national comp level drifters can use them and hit ripple strips sideways at 200kph without issues, somehow I doubt some phaggot in a VW doing 3kph to get up a wooden plank into shallow driveway to go to a circlejerk hardpark meet has anything to worry about
I dunno, examples of drift cars with limited use with shock loading can't really be compared against long term use with multiple heat cycles.
Cheaper wheels & metals would fail due to heat cycling & cracks propagating.
Drifters would probably use multiple sets per season & wouldn't clock up near the amount of km's a daily drive would do...
My drifteks have had a very hard life so far, road and track. No issues as yet...
The missus Audi rims are shite though, leaking from the factory and cracking badly through the lip from careful road driving. I have also cracked oem 350z rims, and seen a few others cracked also.
LOL
Send someone a vector graphic
"Do you have a better option for the diagram. We are putting it in our flyer and the resolution is quite poor."
Send proof of resolution being adequate by zooming in on the vector and screenshotting it.
"That's much better, I'll use that instead" - referring to using my screenshot jpeg
  • Like 1
    • Thank you, 100% the intent. New coils were due and the 17" sixers look/feel loads better than the stock wheels. The aero options are so spot on.   Thanks for the warm welcome, all!
    • 98 r34 gtt Been rocking my latest setup and car running like never before. Have put a good 200 miles on it since all the latest changes and additions. everything is dialed in and have been driving it a bunch.   However, all a sudden last weekend as soon as I pushed throttle passed 4k and the engine stumbles, (slow or fast acceleration) hesitates and doesn’t go above 4100 or so, like a misfire. Everything else seems fine. I had a “good” set of coil packs that I removed from car when I first got it when I changed them over to new coils. I swapped out current ones for those, but no change. I also changed the plugs, no change. Seems to rev over 4 when out of gear with no load just fine no “misfire”, but as soon as its in gear with a load of any kind, it “misfires” as soon as rpm drop back below 4 k it runs perfectly, smooth, starts, restarts and drives fine as long as I keep it below 4 k while in gear. All readings look fine, no CEL   Any idea as to what could all a sudden cause an issue when pushing rpms passed 4 k?
    • When you say your cams are 272/262 is that 272in and 262ex?
    • We're arguing semantics. I am saying 45 accel and a 55 deccel ramp are "2 ways". Even a 45 degree ramp and an 89 degree ramp is "2 ways", because it is literally... two ways. The cusco 55/30 ramp is a 2 way. It's two ways. I get it though - in normal nomenclature a "2 way" would be 45/45 or 55/55 or 60/60 i.e the same locking in both directions. And something like 45/65 would be considered "1.5 way". I would then say if we're getting into the nitty gritty then every locking diff is a "2 way" diff and we should not speak in 1.5, or 2 ways but ramp angles instead. Which ofc if one of those ramp angles is 90deg, that side is not doing any locking. :p So Nismo don't obviously sell 3 things. The fact of the matter that they only sell two items really goes to show that there's a 2 way and a "1,5 way" which is really a 1 way. I believe the actual lockup for the 'adjustability' of the GT pro is really just setting preload for when the ramps actually start locking up. It's not changing how much 'wayness' there is. It is (somehow) horribly explained. People just buy whatever diff and go "locks up good bruh" and that's what ends up on socials forever.
