i love the people that go on about Reps being deadly...
If half the national comp level drifters can use them and hit ripple strips sideways at 200kph without issues, somehow I doubt some phaggot in a VW doing 3kph to get up a wooden plank into shallow driveway to go to a circlejerk hardpark meet has anything to worry about
I dunno, examples of drift cars with limited use with shock loading can't really be compared against long term use with multiple heat cycles.
Cheaper wheels & metals would fail due to heat cycling & cracks propagating.
Drifters would probably use multiple sets per season & wouldn't clock up near the amount of km's a daily drive would do...
My drifteks have had a very hard life so far, road and track. No issues as yet...
The missus Audi rims are shite though, leaking from the factory and cracking badly through the lip from careful road driving. I have also cracked oem 350z rims, and seen a few others cracked also.
LOL
Send someone a vector graphic
"Do you have a better option for the diagram. We are putting it in our flyer and the resolution is quite poor."
Send proof of resolution being adequate by zooming in on the vector and screenshotting it.
"That's much better, I'll use that instead" - referring to using my screenshot jpeg
  • Like 1
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
