P.S. old mate came to Australia as an immigrant at 17 living at his brothers house and pissing money away on booze until his brother told him to get his shit together and get a job
Nek half century - slightly more successful than brother
For a guy worth 100mil plus he is ridiculously down to earth
Drives S350, modest 4 bedroom house, small holiday apartment in Lorne
General manager sold his 10% share too
Which sounds like fk all
But is $20mil+
I rushed to buy shares in parent company but they halted trading on the ASX before they told us lol
They doing a share offer to raise capital for the acquisition anyway, at a 5% discount to the last traded price...these things usually stop the insider trading.
I have to hand it to the LNP. Since the spill motion (well about a month after) they have been playing the game a LOT better. This could even get them over the line.... Wouldn't be surprised if it's under Bishop though... she played the bali 2 thing very, very well and won a lot of left wing voters over.
Like you?
  • Like 1
anyone know the australian definition of unemployed? over the age of 18 and not working? any adult collecting welfare? any adult not studying and collecting welfare?
6.5% sounds surprisingly low from what I seem to come across... though people with degrees looking for full-time work in their field, whilst working in unskilled areas is probably a lot higher than that.
Not all unemployed people are on benefits... "between jobs with decent savings or a working partner" etc...
I'd think it'd be a measurable figure like welfare plus a percentage to cover "others"... (Variable depending on what report the figure is going to be inserted into and if they want to make it look better/worse than it is)
+1, its like they realised their public image was becoming toxic and the ALP didn't actually need to do anything to make it look worse. Certainly seems like they've hired some new PR staff who are getting sh!t back on track...
I'm still sick of these bs claims of "We are going to offer $xxxM for Public Positive Funding #1, but only if the opposition doesn't block Public Negative Funding #2 that will fund it... so if it's blocked, it's the oppositions fault that we're not supplying the funding we promised"
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
