It was supposed to be Alex's post quoted but this forum app does weird shit like that... Nfi where that post even came from, it's nothing I've read anywhere
yeah, I clicked the link to original thing and it just crashed my phone app... presumably due to the extreme retardation of the thread
Jono what is that ramen noodle contraption and how much do they cost? Might be easier than doing my shit on the stove
Interesting drain hole
lol'd hard at chicken strips, but there's an example of something looking shit and tasting good - I know that shit tasted good
wtf you on about? is there another thread im missing out on?
I know a guy who is in the market for a good 135i, srsly he is out test driving them now.
What's wrong with them?
Nothing it's perfect for a hairdresser or flamboyant tax evader Edited by alr33x
Supposedly they respond well to a little bit more boost, and BMW engines are good.
370rwkw in a 135i, with BMW everything else? 3L modern engine for dat response.
Why would you ever want a R33 in relation to it other than cost?
Srs question. Would strongly consider one if (when) I ever write my car off again.
Speaking from experience? :P messy breakup? that's what I'm worried about, bitches going cray cray and destroying your place if / when you want them to move out
That rule doesn't apply if they're paying you rent right..?
yes and no. certainly not messy which is good.
you can be smart about it but what freaked me out was that if someone is applying for welfare and meets all criteria except is living with a spouse/bf/gf/whatever, that person is then financially responsible for the other (if you earn enough, and by centrelinks standards it wouldnt be much). living together for 6 months that is.
Also, i had planned to go down the path of getting a legal documented created to state X was a tenant and paying rent, on the bond etc. not de facto by default. I never ended up following through with it though.
yeah mates mrs stays here like 4-5 nights a week too.. might have to have dat awkward convo and ask for contribution toward bills if shes gonna spend more than 50% a week here..
f*kn jump started in iracing and screwed my race up, then its annoying that you gotta wait another hour before any more official races lol
Edited by UNR33L
What's the Altona rental market like Alex? less stigma than Laverton...
good but you wont get much in altona for 400k unit at best and even then im not sure these days.
wouldnt worry about the stigma its not your problem lol
This happened in Project cars. Didn't know I had hold the brake pedal for go karts, it started rolling forward and race ended straight away. Stupid game didn't even say I got black flagged.
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
