Basically spoke to him and agreed upon fri night/sat night/ a week night - was respectful of my house my rules type of thing and apparently she asked him to ask me about if it was all okay how often she was staying
Then the request came in 'can she stay this thur as well, cos she has meeting on friday 10 mins down the road' & 'she's coming over tomorrow already' and requested it be started next week.. (lets not forget she was here THUR - LAST NIGHT) basically said limit it or contribute
Edited by UNR33L
I think a weeks grace period is fair. Considering the impact to cost is minimal. Want to be seen as harsh but fair, not an arsehole.
Change management 101
I agreed to the start of next week, as long as it actually happens
#daysofleighslife
  • Like 1
#daysofleighslife
Well with any new policy, it's typical for people to test the boundaries to see if there is any consequences.
The moment there is no consequence, the change reverts back.
In the event of the perfect excuse for the extra day or two; what agreement is there to deal with such circumstances?
24 hours of lemons at wakefield on the 28-29th of october
seriously thinking about entering lmfao
car must be under $500, including mods, excluding safety gear and tyres
what the f**k can me and my mate buy that will hold up?
would anyone else like to form a team?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
