How do you drive around with broken suspension and not notice till you look under the car?
More to the point how do you have plural damaged suspension?
car has accident history? (or is this a new shell?)
"Greg"
This is a new shell.
Yes I meant the hankook RS3 sorry. If they are equiv, and $250 a tyre, well.. that's some coin saved.
re: My suspension
I hit a kerb, hard. Damaging a wheel, and bending a tie rod end.
Got that fixed and wheel repaired and new castor arms. all good.
Went under car, noticed the bracket I don't know the name of (what the front sway bar bolts to) has literally snapped off in half.
So that's nice. No idea when that happened.
I also asked TT to set my ride height at 350FR and 345R height. It felt floaty as FAAARK in the rear and I just blamed it on hicas till I actually measured the car and found the front is 330mm and the rear is 368mm.
So yeah....
How f**king hard did you hit it!? I went through a HUGE pothole a couple of weeks back. Took chunks out of both LH wheels and threw my alignment out. Gonna call the council and see what they'll do about it.
Working side (for reference):
Damaged side (for lulz):
Note: I did not notice this occur. It happened some time after traction tyres installed the castor arms and replaced inner tie rods.
Nah, ever since I got the rears put in, I noticed it felt really tail... 'rolly' as though the weight balance was 99% front, all the time. But I supplied the struts and springs to TT, as they came off the old car.
But stupid me didn't really think about the fact that while the fronts came off my old car, the rears struts were swapped, so the setting for rear height was lost when that happened. Did give them ride heights but as they (TT) figured they were swapping from one car to another they didn't need adjusting.
I had no idea the front sway was basically removed from the car via kinetic force.
If it all gets fixed up and it still feels weird then I dunno. Car didn't have that behaviour on the springs it initially came with, nor did my old car with the exact same setup.
but I'll probably blow my engine up again between now and when its time for another alignment
so this was the tyre that won street class at WTAC first 2 years.
then Yokohama sponsored and forced people on to their tyre.
so yeah it good.
That's The only prob with NT05's
The indicators coke up reeeeally fast. The trick is to not give a f**k and drive the shit out of them anyway. I used to rock mine well past the indicators
This is what I did.. although in wet you had to be real dam careful
I think I got 10,000km or maybe bit more out of them.. rears were shagged but fronts were still fine, usually I go down to the wire.. alignment Greg?
Edited by UNR33L
AD08 >>>>>>>>>>>>>>>> RS3
By far.
Why? (srs question)
Longevity?
The NT05's are just touching the indicators in the center now, on the sides there's maaarginally more, but barely enough to catch a fingernail on.
Where else to go for alignment duties? TT always been nice to me, but heard a few things now...
i havent really tried many reputable workshops in the south/east, but i still happily do the drive to Thomastown for Centreline.
Yeah i got an easy 10k from the fronts for daily duties and a few deca's. Probably would have got to 15 but I usually put them in the rears and fried them.
I disagree about the wet though. A car that needs NT05's is going to f**k you in the ass in the wet no matter what
That's a good point, when road is just wet its true it's more so when it' soaked with a few mm of sitting water even shitty tyres with channels to get rid of the water makes me feel a little better instead of a flat bald tyre aquaplaning
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
