A couple of people have done a different pole; I noticed the X and Y variables are different; prolly had a few different policies and standpoints on different issues hence parties have moved around between graphs.
I know Leroy has done a few different poles in his lifetime.
I know Patrick is a different Pol.
Wait a minute.. didn't you and Simon go to highschool together..
It all makes sense now
Just Primary School (Grade 5 and 6 I was there)... Then he went off to some retarded High School and didn't follow the logical path to Vermont Secondary College like the rest of us...
Unrelated, his mum picked me up once and took me to the circus along with another one of our mates ryan. #memories #scaryclowns
  • Like 1
I wanted to go Vermont high...folks said nah f**k you private school is better.
Also, did Ryan ever come out as gay? I know his brother was. A lot of people suspected Ryan was too, though I know when we were younger he had a bit of interest in girls and even a sort of girlfriend - all pre-adolescence though.
Unless he's feeling awkward about it and calls you up on it, I see no reason to make a thing out of it. Unless he's an egocentric flamin mongrel he's probably also aware that you might be feeling awkward about your in jest comments over the years. My personal view outside of the humour I post in here is that sexuality doesn't change what that person is to me, no more so than what kinky things a heterosexual person does with their wife in their own time that's also of no consequence to me. Sexuality is just another characteristic of the person - skin colour, big ears, tall or short, shy, intelligent or dumb. I therefore don't believe it should be off limits for jokes or mucking around. My brother is gay and I still pay him out with those words on occasion, not because he's gay but because I'd say them to anyone else too. Him coming out doesn't change this because I don't think sexuality should impact or change how you treat someone either. If he said that it offended him, I would be more sensitive to it around him just like I would anything else I say that offends people.
But I would probably also engage in a discussion about my other view on gay slurs in casual conversation: I think that once upon a time they were used exclusively as an insult with the implied connotation that a homosexual was inferior or different in an unacceptable way (and sometimes still are used this way), however the more common use of these words as insults these days, particularly amongst teenage guys, has its own meaning which is far removed from the gay bashing it used to be. Consider that many teenagers using such words don't even know the full extent of their meaning. This is why I'm not apologetic for any instance of using such words when my intention is not to hate on gays.
However - like anything else I say, if someone were to take offence I might be more sensitive about it afterwards (after explaining my viewpoint), not because I necessarily agree with them, but simply because I'm not a total flamin mongrel and I'm more for keeping the peace.
I also wouldn't retrospectively apologise for what I've said not knowing they have taken offence to it - if someone takes offence to something at the time, the it is up to them to call you up on it then and there, or else they are more or less condoning it to continue by way of you thinking they are okay with it. People can't change if you don't give them opportunity to or the boundaries to play in. I might be more sensitive towards a topic from there on if someone has made it clear they are offended by it, but certainly wouldn't feel I've wronged them in the past.
tl;dr: I don't hate fags
Did you just try & school me on change management?
btw you just stole your viewpoint from South Park re: what people think of annoying motorcycle riders.
  • Like 1
The fk is this shit? son this ain't the sisterhood of traveling pants we ain't got time to read this shiz
  • Like 1
Haha nah always felt that way about it, but I'm one to look at intention more than the face value of a message being communicated. I had forgotten about that episode though - brilliant piece of social commentary. Chris Rock also had a funny way of conveying the viewpoint:
  • Like 2
So my R34 xenon light blew tonight just as I was about to go for a drive :/
Does anyone knew where I can get replacements ASAP for them? Can only seem to find replacements from Germany...
Apparently they are Phillips D2R but the exact one for the R34 is impossible to track down. Need it ASAP.
Scroll past it faggot
Or read and learn; it is afterall right wing propaganda
Want it ASAP
And put aftermarket HIDs in
So it looks like I can just install any D2R bulb? So would this work for the R34 GTT with Xenon headlights?
http://pages.ebay.com/link/?nav=item.view&alt=web&id=190440247004&globalID=EBAY-AU
Or do I need a full HID kit?
Edit: sorry, just read above post. yeah basic D2R should do the trick.
im going through the same thing. D2R fits in the socket, but you need the plug and ballast to fit the back of the globe.
during compliance they removed the ballast and cut some wires in mine. not sure if i can be bothered replacing the gear.
    • So, this shouldn't be such a mission, but there were a few tricks so I thought I'd post up a DIY for it. This was on a Q50 Red Sport but I doubt any other V37 model is very different (maybe just less steps for the intake heat exchanger hoses) I pulled the radiator out to flush it because the car was running hot at the track, but obviously the same steps apply for changing a radiator for any reason including an upgrade. If you are removing the radiator, you of course need to drain and refill, so have 5+ litres of blue coolant ready. You don't need to drain the intake heat exchanger to remove the radiator but depending on your plans you may need a couple of litres for that as well. You will also need something to deal with the auto transmission lines, I used 2x 8mm rubber caps on the radiator side, and a short length of 8mm pipe on the car side.....unless you can block these lines quickly you will loose AT fluid and it may be enough to hurt the transmission if you don't refill it. Other than that....lets go... "First, jack up your car". Yes really, and put it safely on stands. If you are not confident doing that you need to give this job to a mechanic
    • If the forester is anything like our old 2007 GTB Liberty, I could near on run ling Long's and "rate them", as no matter what, it just hung to the road, even when abusing it in a hard launch in the wet, or throwing it at corners.
    • LOL, all of the CAI like Craig I just need to put a hole saw through my bumper Done and dusted, the car runs, which is nice, I'll take it for a spin when the weather clears up Just need to put the bumper back on for good
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
