Walk out to car to find right rear AD08R nearly flat
Either fast leak or dodgy neighborhood fkin with my property again
Lose lose for Birds
one of my AD08R's deflated unnaturally quickly. other 3 were fine. was in a backyard, so no one had touched the car.
That's some Greg shit right there
Did it do it again or a one off?
Fitting AD08's to my car right now
Got told the fronts (Michelin Pilot sport 3's) are a horrible match and almost certainly will result in me binning the car
Greg issues occurring before even using them now
Widths of Front vs Rear?
I wouldn't say the tyre itself is a horrible match... your fronts aren't hardly 215 Chinese tyres... Unless the tyre place thinks you're going to be tracking it... in which case I'd be recommending AD08R's on the front as well or the rears will just push you off the track in a greg level understeer.
Coming from 245/275 Nitto NT05's
235/265 now
Pilot Sport 3 fronts, AD08 rears.
Did say I may track it, but he was more concerned i'd bin it driving in normal traffic or highway cruising.
All tyres involved were a great deal, etc.
Figured it'd be fine, if anything the PS3's should be more grippy than the AD08's, hence them being on the front of the car.
But yeah. Slip angles apparently very different, told to take EXTREME caution, and I'd notice it within 5kms of driving the car if its gonna be a problem.
I have AD08R 265 on the rear and AD08 255 on the front
It doesn't understeer really, in spite of the fronts being a street version of the rear semis
Actually is quite balanced feeling
I also postulate that the rears will wear down faster and return to a slight oversteer
It doesn't understeer really, in spite of the fronts being a street version of the rear street tyres
fixed that up for you...
  • Like 1
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
