Anyone know anyone with a Nistune and flex fuel?
Do you need to get the nistune board sent away to be updated?
How does Trent do it on a drive in and out basis? I assume he just swaps out the old and new updated boards for customers?
FYI car is getting tuned at Racepace, and i think my board needs to be send to be updated
I remember having a pocket PC (windows ce ftw) in year 7 and copping never ending shit for it - these days you'd get bagged if you didn't have a more capable smart phone lol
nisstune say they need a reflash:
http://www.nistune.com/news.php#news21
not sure if trent has the software to flash them himself or if he just keeps an example of each on a shelf?
I was slated for a career in IT circa year 10 but careers counsellor advised against it because it was a "flooded industry"
flamin mongrel had no idea
same here, got convinced out of a great degree at swinburn, on scholarship and 3 semesters a year to get you out early.
to do chem eng at melb uni.
such a dick move.
lol isn't there more IT jobs on seek than any other classification?
Edited by UNR33L
Brah.
Welcome back
Housemate has Nistune and Flex.
Don't know if you need the board to be sent away to be updated. My housemate got his going after it was released for his S15.... works well though.
I'd wager you'd have to contact Nistune to be 100% sure
wanna know what the careers computer findmatron came up with for me?
jockey
srsly
such a dick move.
The careers counsellor he replaced was much cooler
Used to play counterstrike with us at our LAN parties and was pretty good at it too
Those were the days when it wasn't strange for a 35 year old man to turn up at a student's house and spend an evening with a bunch of school boys
Sort of
