all my teachers were horrified when I said I didnt want to go to uni.
(I also wanted to join the army at that stage, but luckily for me it didnt work out).
school -> uni -> "job" -> house -> white picket fence -> retire
that mentality could go EAD for me in high school. would have rather run away to eastern europe and sell hotdogs.
Also, Birds: look up Respawn LAN. went to my first LAN the other month. met some nice people. some textbook nerds and some were that new breed of nerd with gym membership and a hairdresser. CS is still the rage.
I still play cs online. Sadly a lot shiter now than my l33t days
Re: Respawn lan, went to a couple of them years ago back when internet speed and data allowance was low so you'd 'leech' f**k loads of shared files HD movies etc and pretty much go just for that + some gaming. Dont see the point these days with how good internet is now.
I suspect the buff guys you saw at the recent one were my mates that went and hardcore into gym lol they came 2nd in the dota comp and won $250 each or some shit
Edited by UNR33L
Back when a console game meant Tomb Raider and the only way to play a decent shooter was on a PC, is when you were hailed a geek or nerd
Then came halo and the cod series and see ya later, no recognition for being an OG shooter gamer though
We fought the wars that won't be remembered
  • Like 1
Man my careers counselor laughed at me said I was going nowhere.. As did most of my teachers geez they were wrong started earning well more than them within 2 years
What would have happened if you didn't turn out to be good at selling houses?
Never saw the point to event style LAN with complete strangers, unless you were chasing zero lag. It had it's place with dial up but as Leigh says, now you can get pretty close to 0 latency wih broadband.
Only LANs I've ever done were at houses or in garages. Or Internet cafés like Coolyah at Box Hill if you consider that LAN.
Skipping sport to take a bus there for a precious couple of hours, now I admit that was geeky...but best memories.
Just holidays and work nothing major.
Just losing interest in cars sorta.
But car is back on the road so reigniting my interest
Getting older brah that's what happens. That's why I try get balance between a ok performance and a luxury car for everyday use
Yup
I changed the aftermarket muffler on the Evo X to stock to quieten it down
Getting old :wacko:
haha yep, was sitting on table opposite them. they were getting pretty vocal. but i dont get the appeal of dota or any moba's so everyone seemed strange to me.
i enjoyed the weekend for the most part, defs dragging friends along next time. people around me were friendly enough, one even gave me a free steam game. the racing games were a lot of fun.
I entered the CS:GO Gun Game competition to win a GTX980TI. I dont do too badly online and won a couple of practice matches during the day. nek minit, first round starts: get absolutely annihilated, lowest score in the first round of 140 players (probably).
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
