God I hated customers like you when I was doing gearboxes. Always want somethig that can be everything. Oh I have 9001rwkw but it's my daily driver so I want a soft/friendly clutch but I like to give it a thrash so I need to be able to launch it hard oh and I don't wanna pay more than about $400 for it.
Fast/friendly/cheap, pick two...
Closest youll come to all three for that power level is an NPC Carbotic 10" for around $500. It is an organic clutch rated to 300rwkw and a bit firmer than standard clutch.
Where is your F40 Pat
Haha the mining life is not like as perceived in the east coast.
Trying to save for deposit + pay rent in Perth + pay mortgage in Melb.
Worse off day-to-day living than before ~_~
Final inspection/micolour may have to wait now haha
Or I could disregard financial planning and acquire f40 haha
guys. clutch talk.
car will have around 300rwkw and will mostly be a week end car, sometimes drive it to work since its close etc.
I what is a decent clutch that wont break the bank? id love a nismo twin plate but yeah nah lol
would want it to be nice to drive and be able to take a beating when I track it..
its boiling down to buying the little things to finish it now :)
I like xtreme. dont know about for skylines though.
http://www.xtremeclutch.com.au/en/catalogue/xtreme-clutch
guys. clutch talk.
Just cough up $ for Coppermix twin.
Or find OS twin/triple.
guys. clutch talk.
os twin plate mang, you will never regret it.
or you'll regret it just a little, then you'll learn to be a man.
guys. clutch talk.
This one
http://www.ebay.com.au/itm/RedBull-Racing-2007-RB3-Main-Clutch-Housing-Coulthard-Webber-F1-Part-Formula-1-/281141040011?pt=UK_Sports_Memorabilia_ET&hash=item41754fd38b&_uhb=1
Sunkist, on 30 Aug 2013 - 07:43, said:snapback.png
2009-2010 depending on condition go from 70k to 90k..
2011-2012 go from $110 - $130k.
You want? There's a prestige auction coming up in belmore soon. There's a nice handful of them in there
Might message you again next year sometime... Also thinking Audi S5 etc
Nah it's for maximizing resale for me brah. Not worried about break downs
S5 is easy in the 70k range Dezz my mate almost bought one 6 weeks ago for $74k out 30kms on it
Would be a weapon mines only the 3.2 6 and it goes fair well so the 8 would be awesome
Guest
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
