I remember all my eng exams were 3hours except 1 or 2 which were 4hours long... Don't miss those days at all.
Yup, lol. Sigh. Luckily got a 2hr exam for literature and psych to break it up... But notrly, because that's still 5hrs of exam in one day, ceeeeebs. I just consider it lucky I don't have 2 eng in 1 day
Lol you're chasing it a few days after World Time Attack.... Mistake :P
Wait a few weeks, they'll bring in a heap of them because of how many cars were repping them over the weekend.
lol that's why i figured places would have stocked up!
but yeah I'm hearing around December :(
I have had 3 sets of fake rims, (drifteks, varrstoen's and RG tek's) I have put them through their paces and they have not been any different to the genuine ones except for the wank you hear on forums
all those shots you see of f**ked rims are from accidents that would have destroyed real rims anyway.
end of the day, I have bought real rims and fake, and these days i'd rather put my money towards other shit :P
Bro I was street drifting and I tried to do a reverse entry onto princess hwy bro and I hit the curb sideways at about 80 bro and my rim cracked... Never buying fake wheels again!!!!
Also, unrelated, does anyone have a spare passenger side drive shaft, diff and rear subframe for an R32?
you talk alot of sense brah. unfortunately brand whores dont hear this sense.
Had 2 eng in the same day a few times, anymore than 2 eng in a day followed by another one the next day is GG mang.
Yup
I also like to wear K-mart shirts rather then Hugo Boss ones :P
But the real question is, did those K-mart shirt get him any kissies??
Guest
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
    • And yes with a full tank it will hit limiter free revving or driving 6B6CDF6E-4094-426D-A9CB-6C553475FE36.mp4
