What is this cool event on the 28th of September or is it super hush hush? I might need to book a loooooooooooong weekend, my 30th on the 27th.
it's something that I need to finalize booking in.
All Melb central/surounds, and will be amazeballs
duct tape....answer to everything
if you need a spare wheel for the weekend I could provide a 245 17? mmmm lightweight
I've got some 17's with 235's or 17's with 255's that aren't on the car right now if you want to borrow a set for the weekend :) It's going to be a great day out
It's all good guys, used duct tape and it seems to have done the trick..... on a serious note, won't have time to fix broken studs before Sat. Thanks fellas.
racing badge...yeah whoever put it there should be shot, these are the std ones much nicer:
http://www.enkei.com/nt03m.shtml
They are standard Enkei badges, from the 90's. I think there's supposed to be japlish parables either side of the lettering but they don't last and end up being rubbed off somewhere through the years.
Nah man I know nothing about 32s only 33s
Doesn't matter what year, all 32R's look the same, why does everyone always seem to instal LH N1 vents goofy though?
No headlight changes or differences at all over the years?
So last night was driving down south rd and a divvy van was sitting at the lights waiting to turn right...
He ripped out of the turning lane without indicating, cutting off a driver and nearly causing an accident, then sat behind me for about 1km.
After this he floored it and cut into the bike/parking lane and overtook me on the left again without indicating, eying me off as he went past at 7000 odd revs. He then proceeded to cut in front of 2 lanes of traffic to avoid hitting a parked car.... once again, no indicator.
would have been close to double the speed limit by the end of it.
When in front of the first car, he chucks his lights on (presumably so as to avoid a complaint from the driver he nearly killed) and cuts off yet another driver in order to make it to a U-Turn spot.
He then turns the lights off and drives off at like 40kph looking at me and smiling like a knob.
wonder if i have an EPA coming? :/
cliffs notes: cop was driving like a fuckbag to prove he could get away with it and i'll probably cop an EPA because of it
Guest
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
