  • 1 month later...
Everyone seen the character trailers (Franklin, Michael & Trevor)?
Franklin's looking to be my favourite, I seem to be the only one on the internet that doesn't love Trevor.
Franklin
Michael
Trevor
Edited by alex182
I'm most interested in playing as Michael.
The game looks completely different to gta4. It seems to be massively detailed and with the general quality that rockstar put into their games, I know this one will not disappoint.
Looks like San Andreas stepped up a notch :)Keen for this one
thats exactly why i'm so excited to play as Franklin. Notice he and his homies are usually wearing green articles of clothing? GROVE STREET'S BACK BITCHEZ!!!!!
Yeah 256km sounds a bit much. Be driving for literally hours to get to another city/area
San Andreas was about right, maybe slightly bigger would be O.K
Unless the 256km has water in between and you have to fly to another city etc, like another level. Thats not so bad
As excited as you are, don't build your hopes up too much. There is still that really, really small chance the game may not live up to your expectations.
really really small? since when has anyone in the last few years been super-hyped for a game and it actually delivered?
Other than games where most players are like this:
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
