I emailed them and got this:
Thanks for the enquiry. We can supply these with an 0.64a/r, which would definitely bring them on earlier, although our testing did show the test vehicle surging under light throttle. However, we haven’t tested these with the new surge slotting on the compressor housings, so it’s something that could possibly work, as long as the engine is capable of handling the airflow that the turbochargers provide.
The issue we had originally is the GTX turbochargers push a HEAP of air into the cylinders, but the engine just could not handle the excessive flow, and this is where surge occurred. If the cylinder head is modified is the right way, and you have a nice big volume plenum, the issue shouldn’t present itself. Keep in mind we cannot guarantee they will not surge.
You also need a big BOV if you’re planning on running these (Turbosmart Race Port 50mm should do the job)
no, its the lack of surge port in the original -5 housings pushing the surge line too far to the right when using the GTX wheels
the only place a 2860-5 compressor will surge before the GTX2863 in the correct housing is between 14-18psi, and there is only maybe 2lb/min in it.
as already established, the lack of surge ports is the problem.
whether they've designed these retrofit antisurge covers correctly is anyone's guess, and if they haven't tried them on an RB26 why are they selling them as a bolt on kit as it would appear they have done no testing. even the  A/R of the comp housings match.
Edited by burn4005
From my conversations with gcg they have been tested on at least one car and that car was built by a very well known workshop, gcg also recommended they be fitted to a larger capacity engine due to the extra lag they have
On 27/11/2017 at 4:18 PM, The Mafia said:
Okay I missed those posts. I thought they would have performed better.
Those ones above look interesting. I wonder if you can put smaller rear housings on them, like a 0.63
Why would you put 0.64 rear housings on them?
Lets take a big step back and go through this. First things first, standard intake piping. It's tight, small with horrible bends... how much air do you think those pipes can flow? Put a MAP sensor on them somewhere and I bet you will be seeing a vacuum that Dyson would be proud of! That's issue 1.
Issue 2. Jamming wheels into housings that they don't belong in. The GTX 67 mm wheels in the proper housings flow 46 lb/min flat stick. What will they flow in A) GTR compact housings and B) dealing with the nugget OEM pipework? I bet it won't be 46 lb/min!
Issue 3. Turbine wheel. It's the same turbine wheel as what is used on the 2860 -5 which flows 36/min. Somehow it seems to be a thing to just keep throwing larger compressors at a turbo charger with no thought given to the other side. It's just retarded. Air in AND out. How can you get more new air in when the hot side is choked up like a mofo? If it worked then we would all be running pro mod 88 compressor wheels with stock rear wheels and housings. Somehow I don't think that would work. ?
Issue 4. Turbine housing. THEN you take off the 0.85 housings which would have allowed it to relieve itself a little (seeing that the turbine wheel hasn't grown) and tighten it back up.
2540's - big front, small rear... nuggets
GT RS's - big front, small rear... nuggets.
This really is not a hard concept to grasp.
Why is it that any of these GTX low mounts don't seem to go much further north than 500 kw (on an RB) irrespective or what size compressor wheel is it it? The cars that use the genuine GTX housings always seem to give a better result. Why? Because it FORCES you to redo the intake piping and go to a 3 inch pipe. However, that doesn't fix the poor little hot side. If you get blinded by the compressor map (which seems ALL too common around here) the 67 mm should make some bloody big numbers... never quite get there though. I wonder why? ?
Would love to see the EMAP of a GTX 2867 0.64 AR. It would be absolutely horrendous.
Its no different to say a GTX 3582 and jamming a 0.63 rear housing on it. You're A) not going to make the power the compressor can give
B) Everything is choked up. More heat, more pressure. It's all bad.
Dont want the power that a 3582 can give? Go back a turbo size and keep the larger ass end. It will be a much healthier way of doing it.
  • Like 4
im with captain Piggaz....GT-R owners need to f**k off the twins and f**king man up....
go a big single with a big ass end.... or go fking home. twins are like f**king with a condom, its not the real deal!!!!
  • Like 2
I've told *cough* someone this 10 years ago, he only listened this year.
  • Like 1
  • Haha 1
  • 3 months later...
Tuned today at 101 motorsport, hot and humid day too. Being the baby gtx2860's I think they did well considering.
e75 in the tank                                               nitto 2.8 with otomoto v cam          walbro 460 fuel pumps x 2                          1300cc bosch injectors                              100 cell cat, 3.5 inch exhaust
  • Like 1
2 hours ago, GTSBoy said:
It's not valve float.  Either exhaust flow or timing.
I was thinking the same thing. I would love to see the timing map / AFRs.
GTRSean, can you post a screen shot of your timing map / AFR?
It will be the turbos losing their efficiency and engine pumping losses through small housings.  If you could get external gates onto these twins, I think it would be a different story.
My engine would not rev much past 7000rpm for this same reason, but man, the response was phenomenal.
I had to run 33psi to get 648hpatw out of my GTX2863 hybrids, when trying to get LPM out of small turbos, sadly the pressure has to go up which hurts intake temps and efficiency.
  • Like 1
The bigger the overlap in the cams, the longer (time) there is a straight passage through to the exhaust housing from the intake manifold.
As the pressure builds in the small exhaust housings, you need more and more boost pressure to push against the exhaust pressure to scavenge the cylinder.
This is why you don't need as much PSI on larger single turbos, the exhaust flows much better and the lower pressures of boost inlet is enough to achieve the same LPM of air into the cylinder.
This why I laugh when people gauge an engines "stress or strain" based on PSI figures, it really tells very little, other than how much load the turbo is under, not the engine.
Heat is the killer for twin setups, one because of increased PSI inlet temps and 2 because you can't evacuate the cylinder as well as you can a large single setup, the flow is not there and keeps heat from exiting effricently.
Yes the increased pipework surface area etc is a factor, but is one of the smallest contributors IMO.
Inlet temps are very important, especially when you do the maths for the compounding effect of inlet temps and then compress it in the cylinder, the cylinder temps skyrocket.
Just my 2 cents worth and hope my experience helps others :1_grinning:
  • Like 1
Was told even a gtx3582r gen2 with a 1.01 rear would be nice if I went single.
Pretty happy with the result and how these little lowmounts went.  There is always going to be limitations with these setups but the way it performs, considering people keep asking me if it's a single turbo, I ain't complaining :D
  • Like 1
Are you trying to say there are alternatives that are pretty good
but the Gtr Jesus (motive DVD) tells otherwise... #stockbottemendworldrecord
f**k now I will have to sell the  auto gearbox
#notanymore
I did a 9.609 @ 146.10mph on Wednesday
  • Like 4
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
