New Garrett Gtx2860R / 2863R / 2867R
Gav
  • 3 months later...
New results from a fellowzedder with gtx2863's. First graph was previous. 2nd graph are the new initial dyno results.
Snapped intake cam (twice now) so he changed out all 4 cams for stock exhaust cams (solid, no VTC anymore). New mufflers also and even bigger throttle bodies (58mm to 62mm).
[âIMG]
[âIMG]
  • 3 years later...
A bit of a zombie thread bump but I seen these turbos being shown by Spectrum Motorsports Solutions here in Canada and though they were interesting. How much of a difference will having anti surge housing make vs just standard housings
The surge slot is not there to improve performance. It is because GTX28 comp wheel will bend its shaft in solid housings, the surge slot is made preventing that problem. It looks like a T51R style sort of a insert, should make some induction noises.
Anyway, Result from an earlier highflow we did. Red line is with solid housing, and blue is with antisurge slot. From a S15, internally gated on E85 fuel
Edited by hypergear
  • Like 2
Any thoughts on the 42R compressor map they have? Seems pretty average to me but I haven't done a detailed comparison against others.
On 2/23/2022 at 3:47 AM, GTSBoy said:
Um....no? That's just twin scroll single turbo, isn't it?
BMW in classic fashion decided that TwinPower could either mean a single twin scroll turbo or two turbos. I still have yet to figure out why they bother with twin turbos on the M3 when it seems obvious to just slap a bigger single turbo on the B58 and call it an S58.
Nah, they actually use both words, in both orders, to mean two different things. One order means twin turbo, the other means twin scroll single. They is classically f**ked over by marketeers. Engineers would tell them to go f**k themselves if they had the balls and the corporate power hadn't been usurped by the business school grads.
  • Like 1
718191700_ScreenShot2022-02-25at8_08_15PM.thumb.png.1824290f6935e938355eceb520fddc50.png
From: https://www.bmwusa.com/vehicles/m-models/m3-sedan/overview.html
On 2/26/2022 at 12:51 PM, Dose Pipe Sutututu said:
Because it sounds cool on paper but in reality sounds aids (literally), a M3 with an exhaust sounds horrible. Kind of a reminds me of a stock turbo R32-34 with a loud exhaust, just sounds dreadful.
The F80 even stock sounds awful even compared to an RB26. I don’t know how but BMW figured out the ideal exhaust setup to make that engine sound as terrible as possible.
  • Haha 2
    • It's generally best practise to run 1x run without VCT enabled, then 1x run enabled till redline. Overlay the two torque graphs and you'll find the desired RPM to turn off VCT. Sometimes, it might be even worthwhile turning off VCT earlier control torque/cylinder pressure and using VCT purely to spool the turbo.
    • They sell them in Malaysia for about $4
    • First time I ever have issues with Amazon, but my wife often tells me to keep an eye out for fakes. It finally got me. I wrapped up the conversation with Gates. The gentlemen I was talking to seemed to hate his job but the response time on their technical support is outstanding. He stated that the hose is marked with some variation of "SAE J30R10" but that if you only purchase a 1 foot length like I did, it is possible to get a cut between markings and have a blank hose. To no ones surprise, he stated the swelling and "gummyness" isn't normal and to replace/buy from somewhere else (He mentioned NAPA). I'll toss a small end of the new one in gas for a few days before pulling the hanger out again, just to be safe.  Hose should arrive Monday. For those running multiple pump in tank hangers, you know the joys of getting them out and back in. I'm surprised I haven't destroyed my level float yet.  Lastly once I wrap all of this up, I'm planning on hitting the dyno again in 2 weeks while I'm on vacation. I realized recently that my VCT is set to turn off at 5000RPM. I'm surprised it wasn't increased while I was on the dyno last. I'm expecting I can increase it to ~6500RPM, if not more. Should hopefully get another 15-20kw out of it. I also want him to revisit my knock thresholds. I'm occasionally getting false knock around 3000rpm.
    • I don't believe you.
    • All jokes aside, OP they're just called R32 oem rims as you said. The Nissan engineers back in the late 80's loosely copied the design from the Koya Driftek which was designed and produced about 18 years later.
