Just abit of my finding for anyone interested during the cold this winter, car basically spent two months in the garage with being started once a week up to operating temp and when I went to drop the oil today before the next track day this is what I found.
Oil had completly absored the e85 wasnt even oily anymore ended up like water. This is motul 4100 power, it was fine for 3 months in summer but winter guess its not up to the task for being stationary.
Oh shit...my car's been sitting around for months and hasn't been started weekly...now I have water as engine oil...great..........
Running E-flex + Motul 8100...
Edited by ironpaw
I actually think that mine ended up how it was due to starting it every week and since I have an oil cooler the oil did not get up to operating temp to burn off the moisture it kept getting worse. I rekon if it sits there not being started it will probably absorb less moisture, well this is what Im trying this time.
You are thinking into it too much, just get in , warm the car up and take it for a hard drive through the hills for as long as possible. The majority of the water/ethanol will evaporate especially as you don't have an oil cooler.
As it has been sitting so long you could just drop the oil, not a hard job buddy. Go the Synx6000 this time, let me know what it's like.
Might do that tomorrow night...fancy a visit from me? LOL
I've still got 6L of Motul 300v to use...maybe I should flog that off and use some Synx6k instead?
I'm not sure if you're reading his comment correctly. I'm pretty sure he said it got started and run to op temp weekly.
agreed, i have water literally spewing out of my breathers
Motul told me the 8100 was ok with E85, but 300v would only work if you did frequent changes.
See if you can flog it off on someone and switch to the Syn X?
I've been using Castrol Edge 10w60 with Ethanol for over a year now, oil comes out fine every time it's dumped with no issues. My motor probably gets leant on a lot harder than most :)
How long between changes? that is probably more the issue if people are leaving it 6-8 months etc.
  • 2 months later...
Yep, you won't have a problem. The water/ethanol evaporates fairly quickly once it's up to operating temp.
Summer won't be bad but short drives in winter may cause issues with catch cans filling quickly, and oil going milky, depending on your oil temps.
Something that could possibly be thought about is running higher temperature coolant thermostats like the R34 GTts use . From memory they are 82 instead of 76 and that could have an effect on oil temp and warm up times .
I certainly would not be using lower temp ones eg Nismos in a street car let alone an E70-E85 fueled one .
A .
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
    • Also wanted to say, my new spark plugs are blackened looks like it's very rich. I have splitfire coilpacks but stock coilpack loom and ignitor. I tried directly grounding the ignitor ground to body as well.
