  • Replies 742
New suspension is amazing. Was carrying a lot more speed through 3 and hayshed (both around 200km/hr through the middle now which is significantly faster than before).
I had a lot more confidence in what the car was doing mid corner to what it was like previous.
It was a good thing but still needs a few tweaks. Was a bit lose under brakes from big stops - but especially interesting into turn 1 and between 11 and 12! :) New wing going on Monday might help that though.
I may have done a 1.43.8 too.
Is anyone going to be posting Vids in here?
Unfortunately I'm out of the country while its on, and after going last year, I'd really love to see some footage from this year.
The website had live timing too I think last year, yeah?
Could have a wet track at times going of the forecast, also the wind speed is high...
Should make for some good driving to watch
http://www.weatherzo...y/eastern-creek
unfortunately that will only mean even less running for the big guns - no point wasting tyres (and the car!) on a wet or damp track...
If it does rain, pray it rains all weekend and you'll see a mad dash on Saturday for the top guns trying to put in one fast lap in the afternoon. Could get quite interesting if they're not used to the circuit in the wet.
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
