I'm looking at getting some Enkei RPF1s in SBC, going for a 18.85 +40 possibly for the front. Anyone know if this will fit okay or would I need to go closer to +30?
On 10/21/2018 at 8:55 PM, Gazzaa said:
Kinkstaah is right, the wheels will never fit but with stretched tyres you might be ok. You will need 235/30 for the front And likely 255/25 for the rear
i tried to get heroic and squeeze 275’s on the back but the passenger side has scrubbed away about 2mm of sidewall. With a +25 offset I’m gonn need to downsize to 265/35/18
I also adjusted the camber to negative 1.25 degrees
The wheels have 215/35 and 225/35 on them. I’m ok to roll fenders but if it’s gonna be sticking way too far out i’d rather not waste the money.
thanks for the advice guys. Maybe i’ll try and find 18x9.5 +22 and run staggered tires
7 minutes ago, kyl_er34 said:
If I were to go the 40, would it poke or something?
The higher the offset, the closer to the car. +40 will not fit as you will hit the suspension unless you are using a really skinny wheel. Try to stick between +25 and +35, width depending
That doesn’t sound right for a 10.5. I’m not saying it’s impossible but the tyres would be completely stretched to their limits, plus with such a low sidewall, its not the correct fitment for a r34.
i have. 235/40 stretched over a 9.5 wheel up front
the 10.5 will 100% poke out but with a stretched 255/35 or 245/40 you might be in luck
it mostly comes down to ride height and your suspension set up
this is how the 235/40 looks on the 9.5 (+20)
13 hours ago, niZmO_Man said:
As mentioned above, higher positive number = closer to strut.
Nismo sizes: 8.5" +35, 9.5 +38
Okay well that rules out the +40s. So hard to find the right size in this colour I want. Would I be able to fit a 10/10.5 on the rear of a R34?
Your idea of 'fit' is different to others (and different to mine, which is also different to others)
10 +38 is a relatively common size at the rear of the R34.
With a square setup, the rear of the R34 pokes more than the front does, which was a surprise to me when I put on a square set of rims, or at least it did on my own car.
Like all things - What do you want to do with the car? This will determine what kind of fitment you really want. Talking 225 on 10's means I'm not the best person to advise as I am a more 265 at the front on a 9in rim kind of guy.
But making it fit is a question of maths and geometry really.
shit man, the coupe must be different to the sedan because im running 10.5 +25 on the rear and im about 7mm from touching the coilovers lol. +38 id have no chance.
i guess these things are best to just lie under the car with a tape measure
https://www.willtheyfit.com/index.php?width=265&aspect=35&diameter=18&wheelwidth=10&offset=38&width2=265&aspect2=35&wheel_size=18&wheel_width=10-5&offset2=25
According to this, it'd be 6.8mm closer to the suspension Strut.
Note, did say 10 +38, not 10.5 +38. I had a 9.5 +27 on the back so I obviously had much more room on both sides.
This is just my personal opinion but do not stretch your tires too much or else it makes the wheel look like hub caps.
As if that's the reason to not stretch like that!  How about driving on the sidewall?  Or loading the sidewall completely contrarily to how the engineer designed it to be loaded?  Or how about setting it up to be popped off the rim edge when you hit a rock?  Or completely defeating the point of rim protectors on the sidewall of the tyre?  Or ruining the dynamic performance of the tyre?
Edited by GTSBoy
Well yes, and all that too!
But my pet hate is “Stance nation” crazy camber. I just don’t get it.
16 hours ago, demiosdd said:
How about 18x9+40 245/40/18 all round
The offset is too low for the front I believe.
Use the website willtheyfit and put in your current setup, get the measurements, grab a tape measure and see the difference for yourself.
1 hour ago, demiosdd said:
Yeah I don’t know the setup atm I want to run 18x9s all round if I can with out the wheel sticking out
18x9 + 30 is what you’re after my friend
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
