Knew the R888 were too 'soft' for our heavy cars :P.
I said something like that earlier in this thread and IIRC an mx5 guy said they were shit on his car too... So i guess they're just shit. Cheap tho.
  • 3 weeks later...
I am looking for a tyre that is good value for money and offers the best performance for the $$$ to have a go at a few track days.
The car it an R34 GTT. 320RWKW. coilovers, 350mm brakes etc.
I would be putting the tyres on a seperate set of rims to be put on to drive to the track, on the track and back home. Would be from Canberra to wakefield which is roughly 100km each way. I have a separate set of rims and tyres for daily driving.
Rims are:
Desmond Regamaster
17x9 + 38
17x8 +35
I was thinking of getting Nitto NT01
255 40 17
225 45 17
Should be able to get a full set of tyres for around $900. What do people think? Are there any better value options out there?
You talking about the soft compound Z221 - the C7?
How are they relative to the A050's?
There are part numbers on the Hankook website for the tyres which may line up.
So in 255/40/17 hard is 1010343, medium is 1012650 and soft is 1011508 apparently.
http://www.hankooktyre.com.au/Product/MotorsportTyreSemiSlick.aspx?pageNum=1&subNum=5&ChildNum=3#Z221
Just curious because I would like something a little harder than an A050 and better than an RE55. Almost everything else appears to be sht.
Rims are:
Desmond Regamaster
17x9 + 38
17x8 +35
255 40 17
225 45 17
NT01's will be fine to drive to and from the track on but I'd probably run a wider front tyre if I were you. See if you can get the 255 to fit on the front, if not a 245.
I learnt the hard way. Bought a pair of bargain secondhand 275 Z214 C51 "Mediums" for the back of the Soarer, only to find they were harder and less grippy than the 245 NT01s I had on there. I had NFI about the Hankook compounds at the time, but "medium" sounded like what I wanted for sprints. Wrong! They'r enot that old and had almost new tread, so at first I thought they might just have been cooked or heat cycled too many times. But a mate who runs C70s told me about the compounds... At least it was only $100 bucks wasted.
I bumped into the Hankook rep up here at a hillclimb and he explained the C70 "softs" as really being medium compound and the C50 "medium" is really a hard compound. C90 for Hillclimbs. C70 for Sprints. C50 if you want to do a 3hr race!
  • 3 months later...
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
