I needed a pair of wheels when I got my 265s all round too. I went with Koya CR Tek - cheap, strong, and proven on the race track.
18x9.5 was widest they have, but that's perfect for 265s anyway. Offsets are cut to your specs.
  • 3 weeks later...
On 7/19/2016 at 7:12 PM, Duncan said:
lol you should probably say, or update your sig then :P (edit: make that profile, I can sort of see it in your sig now:blush:)
you are probably limited to 8" on the front of a 33 gtst unless you are putting larger guards on, and that means no larger than 245s.
as for brand I'd just ring the local motorsport suppliers and see what they have....I haven't bought slicks for years but I think they are worth considering for track only
I run a 9" R33 GTR wheel (+30) with 255 z221 on the front with no issues.  Guards have been rolled though.
On 7/29/2016 at 9:56 AM, Adz2332 said:
more or less what i was thinking....
Might grab a set of the nankangs 265 all round. that way can rotate the tyres.
have to find a set of 18 9.5 +12 or 10.5s rims cheapish
I'm not sure if a 10.5" +12 wheel with 265s will fit on the front of an R33 GTST with some serious guard work?
I've been running 18x10 +12 with 265s up front.  Nothing too serious on guard work, an hour with tin snips & hammer, and screwed on some flares.  Works well, beats trying to roll a lip etc.
  • 4 weeks later...
Used the Nankangs at Mt Cotton hillclimb on the weekend. They were great - work very well from cold. I've never felt a semi work so well in Turn 1 out there.  The sharpest steering response I've ever felt into T1, with not even a hint of understeer and probably the best traction I've ever had on the way out of T1. Actually, they've got excellent traction off all the slow turns out there. I'm very impressed with them. Had to be careful not to overheat them with the burnout - just a very small 2 second burnout to warm the rears was about all they wanted. Any more and they went a bit squishy.
Haven't seen the times from the last couple of runs yet, but runs 3 and 4 were 47.9s which is 4 tenths faster than the Nittos were there (without tyre softener). That's heaps of time at a ~48sec hillclimb, and I reckon I went faster on the last run. Just waiting on the results to be emailled out.
So Harry - at the price point where AR1 (and NT01) live - you're not seeing anything about the Nankangs that's a negative from a clubman motorsport perspective?  Bearing in mind that's about the level of most forum conversations and budget constraints for "average" enthusiasts.
Seems the AR1 on a heavier car, dry track, can do the job for hillclimb (nearly dead cold rubber) and sprints (~10 - 15 minute session so generating a bit of heat) pretty well, faster than the Nitto with more grip generally.  It will be interesting to see how they go for durability.
How do they feel for carcass rigidity, and progressive breakaway when they do slide?
I'm very interested to see what you think overall.  Accepting they're not likely to perform at A050 or Z221 level, these things have to be on a few people's lists when not chasing sheep stations.
They're in a totally different league to NT01s. No doubt whatsoever. There's no downsides to them. The guy who fitted them has been selling NT01s for years, said the Nankangs definitely have stronger sidewalls. They're good on the limit, and when you overstep it. No quirks or foibles at all - they just perform like a good semi slick should. They might not be quite up there with A050/Z221 mediums, but would be FAR closer in performance to those than the Nittos are to AR1s. I'm hoping they release a 295 or the back of the Soarer... Would be awesome for the hillclimb if they release a soft compound!
I've done 3 trackdays and one hillclimb so far, so it's early days to be talking about durability, but no concerns so far in wear or heat cycling.
Edited by hrd-hr30
  • Like 2
  • 4 weeks later...
which nankangs are you referring to??
    • What bedding in procedure did you use?   When you say stutter, what exactly do you mean? Like it feels like someone letting go of the brakes momentarily and regrabbing them again to get you to stop? Re-reading your post, and that is what it kind of makes me think you're explaining, like theres a little bit of a jolt, likely just as you're reaching a stop. I've only had this issue once. And if its caused by what caused mine, you will want to get the car up on stands again and check it over. Mine was a case of a caliper mounting bolt coming out and letting the caliper rotate on the other remaining bolt and gave play in a wheel as it came to a stop. But not every stop either!
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - then entered a hotlap with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
    • Thanks, will do that.  Thankfully they still feel great.
    • Yeah man, absolutely. You can try pushing me all the way in swapping the R34 for an E9x M3
    • It's almost certainly going to be some amount of pads compound transfer onto the rotors. It will probably go away after you've run them for a bit. If not, pull it all out, lightly sand the rotors, scuff the pads, and rebed.
