We have oil pressure. All 10 bars of it.
MLR was here.
Regulator ?
Like mine ?
We could be like brothers that look nothing like each other but have the same demon pressure oil pumps.
Even on the lowest stetting I was still getting around 130psi (9 bar) from it, thats why I had to get the regulator installed which bleeds of the extra pressure with a return line to the sump..
Now it sits at around 100 psi (7 bar) @ 7000rpm, seems fine, at least I hope that it is, quite a few track days and some drag racing later and the bearings are still where they are meant to be anyway.
Anyone know what the max psi that should be run ????
On a side note Im heading out to UNIGROUP this arvo to pick up a new 1mm restrictor, if your cars running and you need me to do some rev limiter bashing hellies in it just let me know......
Major hiccup. Oil feed thread to rear turbo is stripped. Got to ring gcg on Monday and see if they have a -5 core or its a new turbo. Still gonna try and make it by Thursday. "Run in" might be at Wakefield at this rate.
if u still have the precission just throw that on, stop messing around with twins
Don't have time to dick around with fabrication and waiting for parts. I also want a back to back with this head and cam combo.
The turbo is sitting on a desk at Unigroup.
all good! we can do shifts on knocking up the Kms on tuesday night
then full tune on wednesday :D
ready for skids on thursday!!!
We must have just missed you on yesterday Mark, we got there around 3:30... then stayed till Midnight :s
When you trial single let me know what you are doing with your twin setup. I know someone looking for all the fluff needed for going to a twin street setup
You want twin -5's on your car Troy?
The new RH9 alternator. 85 amp oem vs 130 amp RH9 alt. Definitely cant hurt when running 3 044's plus gauges, all sorts of controllers and a half decent amount of grunt.
Call me if you can't get a dash 5 quickly I have one u can borrow
Pete, what's your number? If I can't get one from GCG by 8 am tomorrow I may need to. Ill come up and grab it. Time is not on our side :/.
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
