Area under the curve is more important than top end power IMO, your car will be mental. That's why i designed my car the way i did.
Even at my relative power level i find for street work, it's getting to the point the extra power is useless.
I'm loving my current tune on 98, i can't wait to see it on E85 again.
4 hours ago, Piggaz said:
I believe Scott is spending all day on it today. No idea where it's all upto apart from the information I've posted.
Cant see it making anymore than 480 awkw. That's as much as Scott has seen out of a 8374.
how hard are you planning on pushing it - boost wise?
Whatever 125,000 Rpm is. It will be higher early on then taper off as the engine consumes more air.
So. Bring on 125 k ASAP and leave it there. Boost, who cares but at guesstimate, 30 ish psi as it comes on (late 3000's/4000 ish) and mid 20's at 8000 rpm. With any luck, hopefully less "boost".
interesting. looking forward to it.
Just for fun rather than anything else - i compared my power in the midrange compared to yours - i'm at ~100kw at 3700 - you've got ~270kw - same turbo lol
I need me a stroker kit
just get V-Cam OR Nitrous. OR both?
2 minutes ago, SimonR32 said:
Has the fluff fallen out of Ernie yet? Otherwise not a real EFR :4_joy:
Lol. When are you going to man up and buy one. Piss off that nug PTE ?
Update time!!!!
Fuel is E56 only
Still not bringing it on as hard as possible, just letting it come up as normal (not tuning via turbine speed YET).
Turbo is a EFR 8374/1.05 AR turbine housing.
300 KW at 4000 ish, 461.5 KW at 6000 RPM then it falls over. I didn't see this coming but the issue is the turbine housing is too small! The next size up is a 1.45 AR which is the same housings they used on the indy cars. They were saying that the head is  just breathing like a weapon. Funnily enough, both Petes and Intune's car were able to stretch to 8000 RPM even though their engines are larger!
For the time being I will take it back and enjoy it for a while. If I put the 1.45 on, Scott thinks it will see 500 KW and make even more through the middle by 20-30 KW. However, i'll lose a tad at 3000 ish RPM.
I suppose I better get used to short shifting. Lucky I have 6 gears.
For those of you who are hooked up on boost numbers, 25 psi at 3850 ish RPM but that will improve again. Pretty sporty for a lazy, laggy single turbo :1_grinning:
  • Like 9
1 hour ago, Piggaz said:
Update time!!!!
Fuel is E56 only
The tad you loose at 3000, can I have it please :wub:
49 minutes ago, Piggaz said:
Go put a 6258 on your car.
I built mine so I could have a strong top end . I want to keep it and as tried to get it as good as I could down low .
I don't want to loose anything from the top end, I still can rev it to 8000 if I want .  Just like it a bit different than most I guess :/
That head you had done is something else , cannot wait to see it all working together, what a machine :wub:
Congrats Paul, now enjoy it for awhile and mull on can of worms thats just been opened but was hiding there in front of you.
What brake set up are you running ? Reason I ask you may find that other things may need upgrade first, like stopping ,fine tune the nadling (think you sorted that but f**k me too much alcohol brain damage cant remember shit) then sort last power upgrade, all just subtle stuff. Then you'll have the ultimate skyline weapon.
Brakes are sorted, mate. 365 mm 6 pot fronts/350 mm 4 pot rear alcons. Need to change the front pads, the ones in there are woody nuggets!
Suspension and arms are all sorted, although it needs a wheel alignment. The whole rear end has been out to replace the sub frame bushes.
Cant believe I'm out of rear housing. Quite strange that the 3.2 and 3.0 can go to 8000 rpm but the little 2.8 cant. I suppose those polished ports ain't so bad after all ;).
I have in my head the 1.45 isn't a straight bolt on. The housing absolutely MASSIVE!!!! Adrian (bloke from Insight) said if they made a 1.6 you'd put it on haha.
Data is showing 46 Psi in the exhaust manifold.
Im heading out tomorrow to sit down with Scott. Grab as much data as I can.
  • Like 2
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
