How are you "Finding Nismo" products in general?
Some are useful - others cosmetic
Some are oldies but goodies - some are discontinued
Some are well designed - some are designed better
Would you like to...
1) Post a Pic of a favourite that you own?
2) Post a Pic of a let-down?
3) Caption the Pic with a comment?
My S-Tune Susp'n has served me really well so far...
https://www.sau.com.au/forums/topic/401681-finding-nismo/
Springs in my Stagea are great. The rates are very nice and compliant for daily duties. I think the suspension dept is sorted. Catback Exhaust my avatar is good, very quiet,but retains a nice note with nil drone. Great for daily too, however I believe it's a bit of a restriction in the rear can. Quality also great.
https://www.sau.com.au/forums/topic/401681-finding-nismo/#findComment-6382527
I do.
Just the icing on the cake.
But they look like the short version.
I've got the extended ones.
Yes, mine are the short ones at 5 o'clock in the pic.
But I like your wheels > I bought 'em.
Sigh - discontinued!!! Prices/values seem to have gone sideways now!
  • Like 1
https://www.sau.com.au/forums/topic/401681-finding-nismo/#findComment-6382547
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
