I haven't had any scratches on my nismo wheel nuts yet (that I've noticed), but they probably havent been removed that many times.
I may have to take up Terry's recommendation too.
I also wanted black wheel nuts to contrast with my bronze LMGT4s, so I understand where you're coming from.
  • Like 2
This is how the Nismo wheel nuts look after about a dozen sets of removals and replacements. Swirls are yuk.
Accentuated in sunlight evidently.
I look after my 2nd set much better. No marks with the Rust-Oleum Peelcoat rubberised spray (into the socket).
  • Like 2
Can I play? Bought my coupe and this oil cap was on top of the redtop engine, brought it across to the rb25 when I dropped it in. A little damaged but cause nismo ill run it still!
Also I seen this sticker was available from Nissan a year or so ago, ordered it because it looked old school and cool. Tried re ordering one a few months ago when I seen Yahoo auctions had them listed at a silly price.. NLA now :( Wish I stashed a few away at a crazy price of about $15.
  • Like 2
Dont care so much about what it is but I would like to find the thingo that goes in place of the ash tray to fit it there.
May well be this:
http://www.hks-power.co.jp/en/product/electronics/boost/evc6-ir24/index.html
Edited by djr81
  • Like 1
Car that I have this time to introduce the
ultra-superb! 1993 Formula BNR32 Skyline GT-R 1 owner indoor storage, rain unused, real running 19,000 KM! OS Giken RB3.0KIT> 3037 Twin & OS Giken sequential 6 It will be the introduction of the fast vehicle.
Your car we also carried out, including all tuning and maintenance from normal in jewels and vehicle of the original run deuce-like production in Okayama Prefecture.
Although engine even if the distance did not have exactly the ride last year, has just been full overhaul Performed at the same time as the maintenance because it has passed a number of years, only two thousand KM after construction.
With regard to power, but speed is limited to about 650PS along with the legalization of the current exhaust relationship than the original specification, in the previous specification had been out about lightly 850PS boost 1.5.
Also torque measurement of Shashidai was has become a measurement can not shake off until 80Kgm.
In fact 1000PS over is also a specification that aim comfortably. In addition it also equipped with enough strength for that.
Introduction agency relationships and drives the base vehicle, the vehicle is also high degree of perfection, while high-level up to this point, such as cooling braking I think that it is a vehicle of the not much out with twice.
Tuning specifications associated with the production it also took immeasurably.
Anyone heard anything about new carbon parts for the r32? Apparently omori factory held a little get together focusing on the essentials of the circuit. supposedly show off new carbon parts for front of r32. Im hoping a carbon omori lip or something. The description was very vague like it's a surprise or something.
"In addition, carbon NEW parts be able to show off in front for BNR32! ?"
Unless "in front" means front of the shop lol. Could be translation issue, but I'm anxious to hear what is. Possibly the carbon inlet pipes and air box?
Edited by JTCC
Fujimura makes a carbon front lip for the BNR32 .
My nismo specific range from my current stash of GTR/Nissan literature collection.
Nismo Sports Resetting Menu & Nismo Sports Parts catalogue.
Nismo Street & Sports Parts Catalogue ('01), Altia/Nismo OWN catalogue, Nismo Street & Sports Parts Catalogue ('99)
Nismo Engine Tuning Menu. Left is 2003. Right is 2006.
Nismo Z-Tune sales brochure's including specs of all 4 variants of the Z-Tune
Nismo Engine Tuning Menu with 10 page price list for all packages and parts for BNR32, BCNR33 & BNR34. (Thanks Tim for allowing me to include this piece in my collection)
  • Like 7
I am Glad it went to a good home Raj. Very special collection, I think it deserves this also
  • Like 1
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
