Has anyone ever got a c34 bonnet in the back of a c34?? I couldnt! Lucky its got roofracks :D most i ever carried was 3 sets of wheels when i was getting rid of old crap i didnt want. Wish i took a pic cos it was a snug fit.
Yea. I had to put the bonnet on my home built roof rack bars. Cost $10. The bars that is. I got the bonnet as, " a just in case" for $50. So glad I did as the creep who backed into the 25G still has not offered to pay. Off to QCAT soon to get my $3k plus. I hope.
Having an Art Gallery it is necessary to have a long wide interior, as the C34 has. With the roof rack I can carry lots of framing materials up to 4 metres long. An RS4 is a joy as a work horse.
Yeah modifications will begin when my mate gets back from holiday
Sucks not having any tools while I'm in QLD, also my mate has a hoist now :-)
  • 11 months later...
Due to the bushfires threatening us recently, I bought and loaded into the Stagea two rolls of poly pipe - 25m of 25mm and the other 50m of 38mm. Forgot to photograph it as it was hilarious trying to get it in. Yesterday, 175kg of scrap steel to the Norman's in Penrith and the about the same if not more in firewood on the return trip. See attached.
I lost a washing machine in the back when moving house - who knew they were so big!
mostly though i have pram, childs things and junk
soon to be lots of camping gear and booze for festivals :)
    • From my youth: GTi-R clutch change is a massive pain. The gearboxes are fragile? But the car is super cool and I want one 😢
    • Remember this is 1988 tech.
    • Driveline vibration is resolved. I ended up loosening all my engine mount and trans mount bolts, giving it a good shake then retightening everything and it's gone... Let's just say I was surprised that fixed it.  I've been happily driving it around again but unfortunately put zero time into my direct port/constant pressure WMI setup. I'm on vacation next week, so I'll try and finalize it then.  On a different note, I spent all week fuel/ignition mapping 2x 216L V16 engines. Turbo's were burning glycol and we swapped them out for larger units. We also had planned emissions testing on site, so I figured I'd be there the same week to use their instrumentation and massage any emissions issues out if needed. This was a first for me. Fuel management is similar in certain ways to automotive (i.e air density as load variable) but very different in others. It's all PLC based and AFR's are controlled by air and not fuel. They use a control valve between the turbo and air manifold to control pressure which in turn controls AFR's. Due to this, target AFR tables supplied by the OEM are in pressures and not mass which really through me off. They use air pressure vs fuel pressure tables. I also relied on an O2 concentration sensor the emissions team had in the exhaust. Ignition timing was also all over the place and we were losing a fair bit of power. They're now happily sitting at 16-40BTDC depending on load. We were making about 1600kw at 900rpm at 90% load. Engines were running a lot smoother as well.
    • heh, aint no R32 ever meeting modern targa cage rules unless the driver is veeeery short OP, good luck with the sale, since its already in the land of freedom I'm sure you will find a good buyer.
    • meh, it was a good video, clear about the issue and how he dealt with it. A bit heavy on the RTV and very brave to put an RB in anything without rebuilding it first, but otherwise I thought it was good Dose, I'm not sure that having the pickup forward is a big issue; yes of course the oil could shift under brakes but the sump should never be empty enough for that to be a problem (unless you also have a higher volume oil pump, and that oil can't return from the head to the sump quickly enough)
