I need to use my car in traffic a whole heap, and the engine spends most of it's working life under 3000rpm.
I'm craving more torque between idle and 2500rpm or so- Does anyone know if there's a smaller sized 'turb that will direct fit in place of the current one??
It's a non-neo RB25 if it matters.
https://www.sau.com.au/forums/topic/408058-downsizing-rb25-turbo/
3ltr Shaun, just slap your head on a stock-rebuilt bottom end. Get away with it for a couple grand tops IMO.
I know someone else who did a 3ltr into a Stagea, owner loves it. Made a ridiculously huge difference as it's used for towing as well :thumbsup:
Cutting the back off the car would probably be a bit loud'n'breezy, and reduces security somewhat.
While the big-block idea sounds great, it's sorta more re-engineering and expense than I could be bothered with.
I suspected an RB20 turbo might fit; Sounds a very doable option...
RB30 did it for me - but rather than downsizing the turbo get an electronic boost controller and it will come on to boost a little (just a little) earlier.
But seriously if you stick an RB30 block in your set up and change nothing else who is going to know?
I know of one person that has a GCG BB Hi Flow based on an RB20s turbocharger , at least I think the turbine housing is from an RB20 . This is on an early auto Stagea .
For torque at low revs cubic inches are hard to beat , it can have torque from lowish revs with a smallish turbocharger and thats fine provided you don't expect much beyond say 5-5500 revs .
I think its a good idea to lose the ceramic std turbo anyway and doing so makes them breath better exhaust wise and makes the engine work as a more efficient air pump .
Aftermarket wise as I said possibly an RB20 GCG Hi Flow or a HKS GT2530 would be the go .
The thing is that most go looking for more mid range and higher end performance and use larger turbos to achieve it . If you want same maximums as std and a bit more low down punch overall the turbo needs a little more exhaust flow than the RB25s Hitachis turbine has but in a turbo that boosts a little earlier .
A .
install an electric turbo that sits 3 psi on ideal. lol
Here's a Electric turbocharger that powers the car to 3psi even the engine is at 0 rpm with car key out ignition. lol
Pretty big difference in torque down low
No its not for sale. Just a hobby I'm building.
Any way, if it is a stock turbo and you find it laggy then it might not have all of its turbine wheel, but assume its fully functional and so's the car then you might consider trade your R33 with some thing high comp NA.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
    • To be fair it's the other way around. 300kw is boring in a modern Golf or BMW. They are so competent / well-engineered / devoid of emotion that you have to go stupid fast to feel anything. Whereas the <300kw RB still makes all the right noises and it feels good to drive. Can pull off at the lights with the turbo whooshing and the blow-off pssshing and feel like the coolest kid on the block. Just don't look to the side where you'll see the bored housewifes in their shitbox Yaris/Corolla/Camry that kept up because you didn't go fast at all
    • 300kW is so boring in a Skyline, you'll get spanked by someone's mum's Golf with Alibaba pipes, and an email tune.
