2 hours ago, r32-25t said:
On the knock out rounds you do but not during the free runs
I've seen it at the finals at Eastern Creek.
As for penalties, it depends on who you are from my experience.
I know there's likely more skill in drag racing, getting a car to leave well etc, but I do wish there was some roll racing closer to me. It seems like a great way to blow off some steam with your mates, hear angry spooly boi noises, trap some fun km/h and hopefully not be as rough on the car as hard launches are.
  • 2 months later...
Another great night at Roll Racing
Made light work of a 5.0L V8...
As you can see, my oil pressure gauge is rising nicely as I power through each gear. Stock bottom end , stock gearbox , and still going strong !!!!!! 80° oil temp ALL night baby, this is a turn key package.
watch me gain about 10 car lengths on this piece of Detroit muscle
  • Haha 1
36 minutes ago, Ben C34 said:
Wow you actually did it! You f**king beat a v8 wow man high five.
Wow again, thanks for sharing the incredible moment. How hot was the turbine housing?
Shit yes, wasn't hard pal. Despite your obvious sarcasm, factually your response is bang on!!!
When you gonna race my Kamikaze S15? Wouldn't mind seeing you throw your toys when I dust ya!
Come to Adelaide bro, then we can hug it out.
  • Haha 3
10 hours ago, WantGTR said:
this thing run a number yet?
Not yet...but from a 40kmh roll on a 250m course, I'm trapping over 205kmh at the finish line.
That's serious business for a 2.0L with a torque limited tune!!! The top end is just limitless really - the head is just begging for more boost. It's making the power so easy and I'm f**king slingshotting in 4th gear on other cars.
Even with a stock bottom end its a 300kmh speed rocket.
Is it running boost by gear?
I think I need to dust off my hoon jacket.
  • 2 months later...
I've been spending a little time making some small improvements to the S15. I had the wiring for the speed controller modified with 4 Pin Deutsche plugs to handle some extra current, and fabricated 2 Brackets and mounted it adjacent the surge tank. After that, spent a little time detailing the original paint back to glass finish and finished it with Dodo Carnuba Wax.
Emptied the oil catch can which presented around 15ml worth of oil after 5,000kms of driving, thus meaning there is next to no blowby. Should have the car out at Roll Racing next month, although damn, the itch to get a Samsonas sequential is wearing me down LOL
  • Like 3
    • Messing around with. Twin kit for. Rb30/26
    • For fuelling the Haltechs have O2WB fuel controllers. Very useful for helping tuning VE and correcting for *small* mistakes. Of course if your injector/cam/trigger/sensor data is just wrong (or for a GTT which is not a GT) then you will get impossible reactions to things. I am sure you know this already but the reason people don't typically put haltechs (or any Aftermarket ECU) on GT's is because there's practically no real gains to be had - So this knowledge won't be commonplace.
    • Can someone tell me if the cracks seen in the rear sway bar bushings in these photo's is unacceptable from a roadworthy point of view?
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
