Mates vl calais 1400kg plus driver, with 385rwkw ran 139mph.
Same guy now has aprox 550rwkw vl running 9.0@155 mph.
cozza manual ran 139mph at heathcote, so maybe less elsewhere, and he took the interior out aswell, it ran less mph before that
I really only see it running 134-135mph with interior in it at another track really
cheers
darren
Didn't the R32 GTR "JUN" run 155mph with around 850hp?
R32 GTRs are A LOT lighter than R34 GTRs... We are unable to run smaller than 20" rims on NITTO due to the massive brakes. We cannot put 20" semis on it either as they simply won't clear the rear guards (not keen on damaging the House of Kolor paint!)
You cannot compare a VLT or any other car to this one, either than another R34 GTR that has similar power, a sequential gearbox & was run with 20s with normal "street" tyres :)
Remember - that 10.3 @ 142 was Trent's FIRST EVER run down the quarter in NITTO. To do that time & trap speed straight off the bat was freaking awesome, a lot of wheel spin was experienced on the launch as well so a 9 was not out of the question. We will be putting smaller brakes on the car so we can fit smaller rims & some MT Streets, then take it back down in due course - join the RH9 club!
You're not taking into consideration the weight of the 6-pot caliper/355mm rotor fronts & 4-pot caliper/320mm rotor rears! ;)
How will that equate to 13mph slower down the 1/4? Funny you mention the tyres, they will only matter for the ET. My dads old 350rwkw R33 was trapping 130mph on streets tyres and MT streets but times were hugely different.
Fark there are some serious haters in here...lol
No hate from me, its an amazing car and its even more amazing that its making that power on a standard bottom end. Tuned very well, just curious as to how a small weight increase will equal such a large difference in trap speed.
WEIGHT!!!
Redline is at 8000rpm due to standard bottom end.
Edited by NITTO R34
Here's the setup I am currently running.
Power is a tad over 900awhp or 671kw's @ 30 PSI of boost on E85
PB of 8.97sec at 150mph makes it 2nd Fastest Street Tyred Manual Gearbox GTR in the World
-HKS T62R Turbo
-Jun 2.7lt Stroker kit with Custom 86mm CP Pistons. Godzilla Spec Engine.
-Godzilla Motorsport Race Head
-Custom Jun 295 degree x 11.8mm Lift
-Full Tomei Valvetrain.
-Hypertune Plenum with 4" Throttle Body
-ARE 150mm Intercooler
-Trust Exhaust Manifold with 50mm Wastegate
-2000cc Injectors
-Vipec V88
-M & W CDI Ignition with Weapon X CDI Coils
-5 x Bosch 044 fuel pumps
-Peterson 4 stage Dry Sump Setup
-4 Inch Exhaust
-NPC Twin Plate Clutch
-PPG 5 Speed Dogbox with Ignition Cut.
Here's what 8sec with H-Pattern Looks like. :yes:
This may be covered but whats the exact reasoning for 5 044s?
One was a lift pump to surge tank and the other 4 feed the fuel rail, the car only needed 3 to run that power and the 4th one was a spare just incase one dropped out during a run. Doesn't matter anymore that fuel system has been sold and a new Aeromotive Mechanical fuel pump will be going in along with a smaller 15L Fuel Tank. All in the aim of saving some weight.
What do you think of the Precision 7675?, tried any GTX4202's to compare to?
cheers
darren
Everyone keeps running these large frame turbo's and for what, they take up all your engine bay space, you need a big f**k off steam pipe manifold to hold them up and they don't produce as much HP as the smaller turbo's. I got the shit bagged out of me when i said i was gonna run a 8sec pass with a T62R. Well guess what i done it, with a H Pattern box no doubt, no weak sequential shit that breaks every 3rd run for me. There are a lot of non believer's out there that think everything is impossible, i like to think the opposite. What is possible? And i am thinking that breaking the 8.47sec pass set by the RH9GTR with a Auto box is possible with a H Pattern box. Time will tell but i am confident this is very achievable considering how easy it was to run a 8sec pass, and the car potential is just starting to show.
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
    • Shock tower brace is in +5Kw....LOL
