500Kw+ Club
NXTIME
Engine is out of the car for a couple of reasons. One of them is due to the fact that for some reason the exhaust cam timing had been mysteriously retarded 13 degrees (when it was in another workshops care). Subsequently, the larger valves appear to have been bent.
Will rectify and then probably go back on the dyno in August with full beans.
  • 3 months later...
Made 580RW KW at GT Garages first dyno comp a while back.Slowly getting the old gtr back on the road again here are some parts ive collected over a bit of time Direct twin plate clutch Caple motorsport plenum with 102 mm throttle body 290 11.5 cams with oversize supertech valves and double valve springs bRAND NEW NISSAN HEAD Ross metal jacket with new crank and cam sensors does away with std nissan CAS also brackets and pulleys for dry sump set up50mm pro gate 2000 fuel Nitto DBS headgasket 10.5 to 1 comp JE pistons 2000cc injector dynamics injectors and rail kit 60 psi EBOOST 2 with 4 port solinoid Got coming A GT55 turbo Kernen manifold
http://www.youtube.com/watch?v=CmIEehrvl6w
Any 2.5L Rb25det here?
There are RB25s with that kind of power, don't know of any specifically on SAU off hand. JEM will be tuning one soon which I am expecting will make that power with change in the next few days... most people just go to RB30, which is what I was going to do - or may still do.
  • 4 weeks later...
That is insane man, nice work - awesome wide power delivery! How does it drive? Any plans to hit the strip with it?
Mentioned on the JEM page, unless the compressor profile from the 4094 has been tweaked there might not be a huge amount more flow left in it... Not that 700whp is anything to sniff at haha
Here is my entry
RB26, stock bottom end
Grex 9.1mm cams
ARP2000 head Studs
Greddy 1.2mm head gasket
Greddy manifold and gate
Precision 6262 CEA dual ball bearing 0.84 T4 divided rear
HKS Type-R 100mm cooler
United E85
530rwkw at just under 2bar
  • Like 1
