simon you still running standard valve springs?
suprised your not getting valve float on that boost and with bigger cams
As far as I'm aware they are standard, the Japs put the Grex cams in back in the day and they are only 9.1mm so only babies in terms of lift. Have never thought to check valve springs but I highly doubt it, they didn't even put aftermarket head studs in, just wacked the cams and head gasket in.
I was more worried about head float after the standard head bolts stretched :)
Me like-y, very much. R33 bottom end or R32?
Same motor that came with the car in 1991 (R32) but it's a very low km example... Done 46,000kms
Edited by SimonR32
  • 4 weeks later...
Pretty much same setup as the 8.97sec pass as before a few changes likenew fuel system and Upgraded head components have also switched to Methanol Fuel. Also dropped 140KG out of car now weighs 1280KG. We are currently running estimate 850-900 KW at the wheels.
Best ET is a 8.39 Seconds at 164MPH with a slow 1.3sec 60FT on Mickey Thompson Street Radials, currently makes us the Worlds Fastest street Radial Tyre RB Powered GTR, and also the Worlds Fastest H-Pattern Radial Tyre GTR. Only cars left to beat is the AMS R35 GTR which done a 8.28sec on Radials and 7.98Sec on slicks. Both those time are achievable with our current setup. The car is still not setup a 100% with its new systems a bit more fine tuning.
-HKS T62R Turbo
-Jun 2.7lt Stroker kit with Custom 86mm CP Pistons. Godzilla Spec Engine.
-Godzilla Motorsport Race Head
-Custom Godzilla Camshafts (Top-secret Classified Info)
-Full Supertech Valvetrain
-Hypertune Plenum with 4" Throttle Body
-ARE 150mm Intercooler
-Trust Exhaust Manifold with 50mm Wastegate
-Moran 5000cc Injectors
-Vipec V88
-M & W CDI Ignition with Weapon X CDI Coils
- Aeromotive Mechanical Fuel Pump
-Peterson 4 stage Dry Sump Setup
-4 Inch Custom Titanium Side Pipe
-NPC Twin Plate Clutch
-PPG 5 Speed Dogbox with Ignition Cut.
+ a lot more
http://www.youtube.com/watch?v=KNLs_gONSQ8#t=1
  • Like 2
-HKS T62R Turbo
-Vipec V88
+ a lot more
if you dont mind, what are you using to cut ignition on changes?
if gearknob, what brand, or do you have name of supplier?
cam pm if you want.
thanks, luke.
  • 2 years later...
Joined the 500Kw+ club today with the V3 prototype of my engine. This was the power goal that I had hoped for, as it is designed to be a torque monster with the maximum possible low end performance.
The tune is on E85 (75% content after the 98 octane tune), and was done in Cairns in 33 degree heat at 82% humidity.
Open Deck Engines 3.4lt (3360cc) Block (Rb26 24U based block)
Tomei Spec 2 head, Step 2 cams.
Precision 6466CEA 1.0
Full Race manifold with twin tial gates.
4" turbo back, 90mm Trust TI-R titanium exhaust
Greddy intake plenum
Nismo Intercooler
NPC twin plate
Haltech with IO expander, doing fuel pump and auxillary cooling system control
PWR 55mm twin pass radiator and custom oil-water heat exchanger, plus auxillary rear mount radiator and remote coolant pump.
Ignition project plazma coils
Completely enclosed crankcase breather system, designed to pull the engine into a vacuum under boost.
  • Like 1
Vented back to between the air filter and turbo and running a exhaust vacuum source with check valve?
No check valve, and no exhaust vacuum interaction. Pulls vacuum from the sump and head via a baffle system, to a ventrui on the intake between the turbo and filter. Any oil that enters the system returns to sump like a nismo setup, but at an elevated temperature to boil out any water vapor.
  • Like 1
Have you measured how much Vacuum your pulling in the sump, or are you just managing to pull blowby?
We were preparing to hand make a venturi between the turbo and filter, a few people suggested i look into the exhaust scavenging setups but my thoughts were that it may not work as well on a turbo setup as it does for the V8 guys.
    • OK, Step 3, if you need to remove the valve body, either to replace it, the TCM, or to do a more complete drain.  First, you need to disconnect the TCM input wires, they are about half way up the transmission on the drivers side. One plug and the wires are out of the way, but there is also a spring clip that stops the socket from sliding back into the transmission. On my car the spring clip was easy to get, but the socket was really stuck in the o-ring of the transmission housing and took some.....persuasion. You can see both the plug to remove (first) and the spring clip (second) in this pic Incidentally, right next to the plug, you can see where the casting has allowance for a dispstick/filler which Nissan decided not to provide. there is a cap held on with a 6mm head bolt that you can remove to overfill it (AMS recommend a 1.5l overfill). Final step before the big mess, remove the speed sensor that is clipped to the valve body at the rear of the box.  Then removal of the Valve Body. For this the USDM Q50 workshop manual has a critical diagram: There are a billion bolts visible. Almost all of them do not need to be removed, just the 14 shown on the diagram. Even so, I both removed one extra, and didn't check which length bolt came from which location (more on that later....). Again it is worth undoing the 4 corners first, but leaving them a couple of turns in to hold the unit up....gravity is not your friend here and trans oil will be going everywhere. Once the corners are loose but still in remove all the other 10 bolts, then hold the valve body up with 1 hand while removing the final 4. Then, everything just comes free easily, or like in my case you start swearing because that plug is stuck in the casing. Done, the valve body and TCM are out
    • OK, so if you are either going for the bigger fluid change or are changing the valve body which includes the Transmission Control Module (TCM), first you should have both a new gasket 31397-1XJ0A and a torque wrench that can work down to 8Nm (very low, probably a 1/4 drive one). You can probably get by without either, but I really didn't want to pull it all apart together due to a leak. First, you now need that big oil pan. The transmission pan is 450 long x 350 wide, and it will probably leak on all sides, so get ready for a mess. There are 24x 6mm headed bolts holding the pan on. I undid the 2 rear corners, then screwed those bolts back in a couple of turns to let the pan go low at that end, then removed all the middle bolts on each side. Then, undo the front corner bolts slowly while holding the pan up, and 80% of the fluid will head out the rear. From there, remove the remaining bolts and the pan is off. You can see it is still dripping oil absolutely everywhere...it dripped all night.... I got another couple of litres when I removed the pan, and then another few when I removed the valve body - all up another 4l on top of the 3 already dropped in step 1.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
