Got a bit of a start on the dump. Cut the taper to fit the v-band, ground it perfectly flat (one of the (multitude) of keys to a half decent tig weld I slowly discovered doing the rest of the exhaust...) then tacked them together. Measured up the first bend off the taper and cut the end off the 90 degree bend. Because of the front mount manifold it means the turbo is on an angle so you need to go down and away from the engine at the same time. Makes it a bit trickier...
I'll be cutting more off the end part way through the 90 but tacked it on and I'll work out where to cut it while it's in place.
20191011_212053.thumb.jpg.7c3bdb03fd2a031171b94c9ae73fbd65.jpg20191011_212038.thumb.jpg.65b2f472393c1b03d7215d0623910a30.jpg20191011_212249.thumb.jpg.0d92efaf4ea047f3ab2ed1514ce708ce.jpg
20191011_212301.thumb.jpg.b189a0e0a8818d53cd14e5e5194248ea.jpg20191011_220833.thumb.jpg.5e9b018e95abced6598338f20e1c4355.jpg20191011_230857.thumb.jpg.af1a1ea935465bdc2a62b0b8434686a6.jpg20191011_231020.thumb.jpg.8233c6a2584a2bc94f8f6a2c381dd20b.jpg20191011_231010.thumb.jpg.e2af02083b6eb1dd6c05c0046180f5fe.jpg
  • Like 2
Ha ha!! You’re persistent!
I currently have one point left on my licence so I’ll be looking for ways to be less obvious to inspector Po Po. I don’t think a bonnet exit exhaust and screamer will help me achieve my goals ??
  • Shoota_77 changed the title to Shoota's R33 GT-R RB30/26
Got a bit more done of the dump. Pretty much out the bottom now.
Has anyone come up with a solution for the a/c evapirator drain pipe? Ive gone closer to the firewall than standard. Might just chop most of it off and leave a little dick poking out.
Did my first full (not just tacking) weld on the dump pipe. Did a terrible job ?.  The rest of the exhaust I didn't use filler. With the dump I did so felt a bit uncomfortable. I get so bloody nervous and jumpy when im welding.  I need to chill out and slow the f down!! Once it's ceramic coated it won't be so obvious how nasty it is.
Slow going but good to be making some decent progress!
20191013_150351.thumb.jpg.628035b2604d3bab028ba3d55c04069f.jpg20191012_170836.thumb.jpg.aeddea2fb83d091e364dd472fced7b4a.jpg20191012_170842.thumb.jpg.664abed34b85ba18062c5e8a205c9589.jpg20191012_170831.thumb.jpg.4c2e6dc1738e479a015d7f3db4ab0cb5.jpg20191012_223013.thumb.jpg.ff88cdba70ee438130d704f424c10e68.jpg20191012_223019.thumb.jpg.7b57c5a8a785531d30494275ea9777df.jpg20191012_230423.thumb.jpg.71a88e411375f38a64fd47b65a18d08a.jpg20191012_230449.thumb.jpg.7c082093d07ee9a59d4286127bbee1de.jpg20191013_150351.thumb.jpg.628035b2604d3bab028ba3d55c04069f.jpg20191013_150503.thumb.jpg.c6892a1f1426c1c1822231f4deea3bab.jpg
The only restriction in mine is the dags from my cocky shit welds! ?
I'm a bit scared with how loud it will be with just a rear muffler. May have to put a resonator in it at some point.
Thanks mate. I probably put a bit too much pressure on myself for a bloke who learnt to TIG off YouTube!
The sense of satisfaction at the end of this bloody long winded exercise from having done everything myself on this car will quickly overcome my self disappointment over a few shoddy welds!
Just have to keep pushing while the motivation bus is in town!
I’m up in Sydney for 3 days at the moment so missing a few nights in the shed after work because of that.  Hopefully got a few full days at the end of the week to finish off the exhaust.
A few more bits and pieces done.
I seem to be 2 steps forward one step back. I keep adding and changing stuff as I go...
The dump pipe was getting too long to feed down through the engine bay so I've added an extra v band in to make removal easier.
  • Like 2
Got a few more sections of the exhaust done today.  The dump is almost connected to the cat which is he original part of the exhaust I made when it was still going to be twins.
Went and got a few sections of 3” stainless bead rolled to be used for the compressor side to intercooler and then on to the intake.
Had the compressor housing hose section machined off to allow fitment of a v band rather than a hose. Need to order in the 90 degree bend though as it’s some sort of weird v band size...
Got a start on the wastegate merge into the exhaust. Wow, that was a shit of a job cutting the pipe to fit the exhaust nicely. I just couldn’t get it perfect. With TIG you don’t get too many chances with crappy joins. Decided to just go with it and try to panel beat it into submission! God I wish I had a pipe notcher after that.....  Would have made it so much easier than all the cutting and grinding I did on it.  Took me  Hoooooouuuuurrrrrsssss!!  Started tigging it up using heaps of filler wire to bridge the shonky gaps!
Still a fair bit to do. Waiting on another flex joint (baffle style) as I wasn’t happy with the one I already had. It was way too big. It’s supposed to be 4” but the 4” tube was dick in a bucket. Way too big to be able to TIG. Even MIG would struggle to bridge the gap it was that far off.
  • Like 1
Pretty much finished off the wastegate merge. Man what a mission I made that into.... I reckon i put 5 or 6 hours into that section alone ?
Lucky I'm enjoying it! Such a sense of achievement each time I finish each section.
  • Like 1
    • So, I started this repair and got as far as "fixing" the holes with some fibreglass. God all those years working on boats came back quickly. I decided I'd reach out to some rust guys just to see what they would say about it. I came across a guy about 40 mins away and went to see him. He said the windscreen needs to come out, that there might be some more bits around the windscreen and he'd quote them at the time. But his quote was $300 to remove and replace windscreen and $3k for the damage he can see. He said he could respray the roof for $1200 and the bonnet for another $800 (somebody has previously rattle canned it, its horrendous). This is $5300 + any small additional bits. It's a lot, I get that and the name of one of my fave youtube channels 'Not Economically Viable' comes to mind.  I'm not being financially rational, but I've taken him up on the quote. He's opening a new shop in November with more room, so we're waiting for that. I'll leave the currently missing headliner out until then. I'm looking forward to it being fixed and having the paint looking nice again (lots of clear coat issues on the roof too). / flame suit on.
    • Oh and some up-and-comings; New rear drivers wheel bearing. I'll do that this weekend while the diff is out. The car is already up and the d/c axles and missing exhaust will help with space. This is the last bearing for me to do and I've been dragging my feet on it. I also have some new EBC blue stuff pads for the car and some new brake fluid. I haven't ever flushed the fluid in this car and looking forward to it. I have 600 degree fluid to put in. Not exactly "race fluid" but better than the typical stuff I have been using.
    • A proper clutch/plate type mechanical diff with quite a lot of pre-load and high locking % is better for drifting. Much more consistent in its behaviour. A helical can be annoyingly vague and inconsistent in how it responds under the sorts of abuse found in drifting.
    • Some updates here. I pulled the entire interior out, minus some trim to respray the seats with Colourlock dye. It turned out really nice though I accidentally let the dog in the car after and she scratched up the front seat.  This is what it looked like before, the colour was just washing out everywhere but thankfully the leather was in good nic. Then after the respray   And after the bloody dog jumped in The headliner is out waiting to be retrimmed, but it will stay out now until Nov - see why below. I replaced the stereo/headunit with a period-styled Android headunit. I have no after pics, but I'll get some. This is because of the missing pixels. I tried to fix this twice with replacement ribbon cables but couldn't. Also the bluetooth interface I'd bought for this was crap. Then there's the rusty roof. Pics and info in this other thread. I have decided to get this repaired professionally, but I'll update that thread. This is why the headliner will stay out for now. I'll be getting the roof and bonnet resprayed at the same time the rust is fixed. I also had an interesting issue with my drivers door lock.  For a small period I was having issues getting any 12v power to the car - I mean *any*. It would have no dash lights, nothing. It happened while I was at the shops and I couldn't get in the car. So, we had 2 problems. The most pressing here is that I was locked out. I have only a single physical key hole on the car, the drivers door and no amount of turning would unlock the car. Surely it doesn't need power for this? The second issue is why am I losing all power periodically, The battery isn't dead, its almost like the battery isn't even there. Two issues that were surprisingly easy to fix. You fellow BMW over-engineering lovers will appreciate this. The lock in the door has 5 states; mechanical lock, electric lock, neutral, electric unlock, mechanical unlock achieved at -90 degrees, -45 degrees, 0 degrees, 45 degrees and 90 degrees. Although, the unlock is towards the front of the car, so opposite for LHD countries. Sticking the key in and turning 45 left or right is what is used 99% of the time. It activates the central locking etc. 90 degrees is for dead battery access and, obvs, only un/locks the one door. But because the mechanical lock is never used and is 27 years old, it seizes up. I was totally unable to turn the key far enough to get to the mechanical unlock (At the time of locking myself out, I didn't even know this was a thing). I eventually did it with some vicegrips and teflon spray.  I made a quick vid for other E39 peeps.   The battery issue is totally new to me also - It wasn't making sufficient contact between the post and the terminal. The terminal was bolted on tight, but the car wouldn't have power. After checking the battery with my multimeter I accidentally contacted the terminal and the battery post and the car got power. The battery was only a few years old and in good condition. I cleaned the post and the terminal with a wire brush, bolted it back on tight and never had the issue again. I'm still surprised that despite having solid contact it didn't work. Also, the car was getting Warragamba sized pools of water in the back when it rained. My initial concern was another rust problem. But when I went out on Weds while it was raining and while I had no headliner in I could see a steady stream of water coming through the roof mounted aerial. As this aerial is for the (now removed) car phone I pulled it out and whacked a blanking grommet in the hole. It seems fine now. I'm thinking I might get the hole permanently filled when the rust is fixed. Moving forward and things in progress; The tailgate needs some attention. I have taken all the trim off to clean it all and address some small rust spots. I have partially done all of this but I'll finish it up hopefully this weekend. As all the trim are now entirely devoid of trim clips I have bought a heap of strong velcro and I'm hoping it does a good enough job as any of this trim in good condition is super expensive and usually in Europe as we dont have many of the wagons here. Suspension and brakes!!! This is exciting. In the front; New control arms New sway bar links New lower Eibach springs (the only modification I'm planning on this car) M Sport shocks (these came with the car and will replace the longer shocks in the car) New top mounts Used 540i calipers (stock brakes suck!) New 540i disks and pads (22x296 mm for 528 and 30x334 mm for 540i) New front wheel bearings (thank all that is holy for bolt on bearings!) Annnnd in the back; New control arms New sway bar links Adjustable air suspension arms (fool the car into what the current height is so the self levelling suspension can match the new front ride height) New ball joints I'll also be doing a brake fluid flush while I'm in there. I'm planning on switching the car over to the 16's that came with it so I can clean up and respray the M Sport 17's. They've lost a lot of colour over the years and have some gutter rash. None of this will start until the E90 is back.
    • You mean you will regret it for drifting duties? I don't quite follow.
