Good work man, awesome to see !
Did you find perfect run to be cheaper than RHD ?
The answer to that is yes, yes and yes. They are excellent to deal with and fast delivery.
Edited by Ants
Been frantically trying to put the car back together
So first up the I took the front LHS mudguard off completely and gave it a good wash (really stupid I know but I'm anal :w00t: )
I also got to tidy up the vents in the mudguard for the oil cooler as they used to look like this
Pretty bodgy job done IMO :closedeyes:
Smoothed them out like so with the powerfile....mucho bettera
Then time to tackle the LHS front fender
Glue and sikaflex and other crap on it
Most of it removed and cleaned up with Motospray Prep Wash (which I highly recommend)
the bolts, washers and nuts were pretty fubared
so replaced with some brand new ones sourced from supercheap auto
Photo of front fender put back on car (still not fully bolted back into place but were getting there)
I managed to put the brand new LHS N1 headlight into place
and also managed to put the other N1 headlight on the car, which already has changed the appearance of the car.
Edited by Ants
Ok I am going throw a spanner in the works here and ask for you guys to help me :w00t:
For the project I wanted to put something on that makes the car perform well and looks the goods too (besides the engine itself), so I have been tossing up between
this
Nismo intake plenum - costs $1,982 (inc. p&H, duty + GST)
or this
ACPT carbon tailshaft costs approx. $1,700 after P&H, customs duty and GST (and yes I did the calculations) from Vivid Racing
Please ignore the differences in costs between each items as that is not what I want to focus on (although every $ hepls) and I can only afford to have one of the above. I have heard some positive and negative things about both items but cannot reach a decision so I am going to let you guys do it for me :D
Whatever conclusion is reached, I will buy it and it will go on the car.
BTW my car will be mostly street orientated to start of with but then focused on track work.
Happy decision making!
Neither carbon shaft causes vibrations and nismo plenum does nothing
Happy to consider that option as well mate. But there must some benefits somewhere???
Edited by Ants
There definitely has to be a better way to spend the $1,700 with more tangible results - what are you doing suspension wise? Changing any of the stock arms for adjustability?
I am begining to think that you are right, which is why I probably couldn't come to a conclusion.
Will be replacing the old (worn out) el sport suspension (has HKS) coilovers) with either Tein or BC racing suspension(not entirely sure which one yet). Have not thought about any other suspension mods as of yet. But would like to put down as much of the grunt to the bitchumen so need to think about that too.
Edited by Ants
Having had a carbon shaft, you can DEFINATELY feel the "on/off/on" throttle response impove. However, mine was a bucket and the amount of vibration that was going through the car was rediculous. IF the company could totally 3000000% garuntee that it wouldn't be unbalanced, i'd buy another one and try again.
Torqline in the UK seem to get a good wrap. I know God_Speed has one on his NUR and there isn't an issue.
Really sad to hear your carbon tailshaft was a dud. In fact it is quiet disapointing because you do pay good money for something like that.
Yep, improvement in throttle / engine response is what initially caught my attention to potentially buy a carbon tailshaft. But there seems to be some gremlins surrounding this.
Maybe should bite the bullet and just go with carbon tailshaft and if it sucks well I will put the old one back on.
Edited by Ants
http://www.skylinesa...bon-driveshafts
PST ones seem to get a pretty good rap, looks like a heat issue in the 300zx link posted in that thread with the exhaust sitting right under the driveshaft - $$$ could be pretty good from the USA
Edit: although - shipping from the USA is usually a farce
That Torqline CS composite tailshaft is a nice bit of gear; It is such a shame it hides under the car :D
I have just requested a quote from torqline. Got a feeling it is going to be more costly than the ACPT item...but I will let you guys know :teehee:
Edited by Ants
Worth it if it actually works and you don't have to "make it work". haha
If you do go down the path of suspension arms, etc check out the SPL gear out of the states. Top shelf stuff & all their z32 gear will work for you.
Also, love your build!
Thanks mate,
I Will check it out.
Edited by Ants
    • Kinda glad I never got to this ..    https://www.facebook.com/groups/1483859159195077
    • @GTSBoy This method was able to get readings of -10 to -2, so it looks like its monitoring.  Now I need to figure out why the vacuum on the line provided isn't alternating with manifold pressure.  I went with 2 lines that an RB25 tuner recommended but I'll get a longer hose and try directly off the back of the manifold.  He may have been used to OEM intake setups while I have a DBW setup that removed the MAF and IACV.
    • I work at a car detailing and tinting shop called Quark which gets all manner of German cars in usually (mainly due to a contract with Mercedes Benz Kita Osaka, BMW Nishinomiya and others) but every once in a while something special comes in, like a fully restored 1972 HS30 Nissan Fairlady 240ZG... The shop owner had immediately started applying film to the windows as soon as it was in the shop so the interior was completely covered in towels and plastic sheets. But I could get a few photos of the engine bay which was restored like new. Such an amazing car to see in pristine condition in Japan these days.
    • Was going to say the car pulls up nicely everywhere, especially going into that last long right hander before the main straight. Looks like a lot of fun.
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
