Yeah man I just spent the last our on perfect run website. I wouldnt of known about them otherwise either
I made the same mistake last night, wasted a good hour just browsing.
Perfect Run is awesome. They use EMS, best postal service I have ever used. Took 3 days fro the time of ordering for my HKS cam gear to arrive. Had a problem where I forgot to change my address before I placed the order, sent them an email and they were very good to deal with, sorted everything out no fuss, no delay.
Thanks mate, just needed a bit more confidence in them before i spent a few penny's.
Now to leave this thread back to the build :yes:
Nice update!
I bet you're hanging big time to get it running.
Yes. I'm very excited as it is going to finally be put together and realizing this is a big achievement (for me anyways) Edited by Ants
Thanks guys,
Yes, I believe next week the car will go to mechanic as I have finally received this long awaited package
Brand new N1 front bumper - just to make it more genuine I guess :closedeyes: and will get painted professionally in Nissan 326 crystal white
FRP N1 Bonnet lip - will also get it professionally painted
Cucso license plate relocation kit so N1 bumper remains intact ;)
This is really what I have been waiting for.... Catco 3" High Flow Metal Race Cat - flows 706.2cm :woot:
That's it! time to grab my second beer and watch last weeks F1.
:cheers:
Edited by Ants
That bumper is actually Nismo not N1, they're the same really except N1 bumper is more expensive and is prepainted Crystal White.
Are you certain it's a nismo bar?
Because it only has nissan stickers on there...in addition to that I was not aware that you could procure a Nissan n1 front bar already painted in crystal white, because if that is the case I would probably have purchased that instead.
I always thought that the front bars came unpainted???
Edited by Ants
Yup, Nismo as in the Nismo Special edition model.
The top 4 are painted various colours with the N1 as you can see at the bottom painted in 326, then you have the normal spec unpainted bars(Early & Late) and at the bottom "ニスモ" Which is Nismo.
Hey Ants, if you find out a price on the painted version can you let me know.
I'm looking to get a Gunmetal GTR front bar for my car, so knowing a new price would help me weigh up my options.
Cheers
Cheers
+1.
+1.
Sure thing guys.
Will get pricing this week.
Please note that I will be getting prices directly from Japan I.e not via a dealer in Australia so freight will be an additional cost to consider and budget for.
Horrible news.....THE GTR IS GONE :woot:
gone from my garage :P
so off it went to Gavin Wood Autotech finally :worship:
I followed shortly after put all the bloody boxes of parts in my car
Lucky I have station wagon
car patiently waiting outside of Gav's workshop
there are always some interesting cars in his workshop, just like this crazy s15 drift machine, which allegedly competes in Japan :w00t:
nice R34 GTR getting some TLC
Finally my car where the work is going to be done :D
That's it I promise to take as many progress shots as possible
Cheers,
Anthony
Edited by Ants
+1.
Ok pricing for front bar is as follows:
N1 (painted in 326 crystal white) $893 exc. postage
Nismo (painted in KH2 gun metal grey) $893 exc. postage
Postage will be with DHL and I would estimate to be around the $150 mark but don't quote me on that yet.
All in all budget for approx $1,000 for painted front bar which in my opinion is more expensive than buying the front bar (unpainted) and then getting it painted in Australia.
Edited by Ants
There is no difference between the two apart from the N1 bar only coming in white and the Nismo bar coming in grey. N1 only comes in white because all N1's are white as they were built for race homologation in the N1 endurance series.
Anthony just wondering who do you do your parts ordering through? PM me if you'd like.
PM sent.
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
    • Assuming your brake pads are not worn right down, I'd add a little brake fluid. Is there any sign of a brake fluid leak?
    • Hello all,  I need of some help. On my drive home my handbrake light lit up and started flashing. When I got home I checked my handbrake sensor under the centre console and nothing seemed out of the ordinary. I have scanned my car via the consult port, no codes shown. Checked my brake fluid as well which is half full. Tried unplugging the brake master but it didn't change anything. Thoughts on what it could be? The master float doesn't seem to be stuck. My car is an 1998 ER34 sedan GT. No hicas but has ABS Photos below 👇🏾
