Hey guys, been in contact with scott and Ian to clear up the front splitter rule in open class. Im not sure on the rules for clubsprint and how it affects you guys. Thought I'd post this for all of us as not only were we unsure, it seems many teams have a different interpretation of the rule, Scott helped write the rules and still waiting back from Ian but Scott has responded below with a quick document to try and clear it up. It's not official yet but as the rules currently stand the pictures show what is allowed under current rules by Scott's interpretation.
Scott's response regarding front splitter, cut and pasted.
I spoke with Ian yesterday and sent him an email last night re a few
> changes I think we need to make but as yet haven't documented these for him.
> This rule is one of them.
> I'll put together a quick document now outlining the rule as it currently
> sits and the proposed simple change I'd like to see.
The first two pages show what is currently legal. This is a direct translation of the vehicle profile forward up to a maximum of 150mm. The second page also include allowances for a winglet/canard as part of the splitter plate. I would deem this to also be legal.
Page three shows the result of allowing the 150mm to be measured in any direction. This is currently illegal.
Page 4 shows my proposed change, allowing the splitter to be blended into the winglet section and making it easier to measure and check for all involved. This should make the rule easier for all to understand.
> Best regards,
> Scott Beeton
post-19978-0-58389900-1375494259_thumb.jpgpost-19978-0-22716000-1375494280_thumb.jpgpost-19978-0-33432700-1375494294_thumb.jpgpost-19978-0-83785000-1375494308_thumb.jpg
Hope this helps
  • 4 weeks later...
  • 4 weeks later...
Was driving through Goulburn this morning when I spotted a car on a tow truck....looked closer and saw bits flapping, hammerhead front spoiler, aluminium side skirts....this could only be a superlap car heading to wakie for some testing
not sure who it is, but it looks pretty serious. all c/f and lexen as far as I can see.
  • Like 1
That would be the pulse evo
  • 3 weeks later...
Very weird for me not to be rushed leading up to this event. First time in 4 years I've been going to WTAC relaxed haha!! Can't wait to see you guys run around! Not looking forward to seeing my result from last year get smashed by even more cars haha! I know it's going to be hard watching!
Rushed is a understatement lol
Is good to see the event as a spectator ONCE only my friend :)
  • Like 1
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
