Yea baby
3 x 20 minute session today at ec and oil only got to 115 degrees and water to 99
We're back baby
Only ran on the rsr,s and down to a 1:50. Rubber is well farked and the rear brakes went metal to metal
Also speed was up to 210 with the lower engine temps today
Trust ic pipes sorted the ic pipe issue out
  • 3 weeks later...
new rear pads in
latest mod was two child restrains for the rear
also pulled the harness bar out and put in some parcel tray bolts in so i can run a harnes and fit the baby seat in
after driving it all weekend i cant wait for the q7 to come back from its service
noise, bumpy pos
  • 3 months later...
So I have been thrashing the shit out of this thing regularly and the f**ker just won't die
After the crash bang boom of shock works I changed to HSD and they we're heaps better
Decided to punt the HSD on feedback from a few Tarmac guys
And picked up a set of tein circuit master rs coils for it
They have been rebuilt to tarmack rally specs by race pace
Apparently they are the shit to have
And someone else has already done he hard work
I have some cool shit for this car that I have been collecting and I think next month is time for a proper update with more fasts
  • Like 2
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
